Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: Flash request please..
  1. #21
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Quote Originally Posted by mpattonm
    that teaser is georgeous. actually, both of them.
    Have you tried it yet ? I've posting a download of just the old audio flash, so you can stick it in RR and give it a go.. I have since added a couple of things as mentioned about, but you will get the idea of the slide in menu :-)
  2. #22
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Have you posted a dL??? cant find it
  3. #23
    Feb 2004
    Manchester
    its in another topic :-)
    Flash Teaser
    CdR
  4. #24
    Feb 2004
    Manchester
    Guino.. could you place the slider icon above the flash, I've tried to add a slider a few different ways, but even making a little transparent hold in the flash, and showing the backgound, it still disappears when the flash is placed over it. I have removed the flash to check to see if it is in the right place and it is.
    cheers
    CdR
  5. #25
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by CdRsKuLL
    ok, now i've finished the audio screens, its good the way you can just change the background and it gives the flash a whole new look. Gman I've sorted out the volume and search buttons. Would it be possible to asign the varables mute to on or off and same with the random / search.. that would be kewl as there the only thing missing :-)
    I can most definitely make the indicators set status into flash, I was already thinking of that.. (you should define them like you do with the labels though).
    The trick is: Blinking Labels would not work unless you made them blink in Flash.. :/
    Ride Runner RR's Myspace
  6. #26
    guino's Avatar
    Nov 2004
    Toronto, Canada
    cheers
    CdR
    I'm afraid that to make this work I'd have to completely redesign the sliders in RR. I could do it -- but maybe the best solution would be to allow "cutting" areas of your flash object OFF instead allowing the back of the window to display buttons/indicators/sliders correctly.. I have to try it first to see if it's possible to do it.
  7. #27
    Feb 2004
    Manchester
    yeah cutting an area would be fine, so to display the background underneth, this would then allow for the slider to show through.
    CdR
  8. #28
    Jul 2004
    Tampa, FL
    What sliders? Can the sliders just be made in flash?
    '05 350Z Roadster
    http://www.gregburch.com/
  9. #29
    Feb 2004
    Manchester
    this one
  10. #30
    Jul 2004
    Tampa, FL
    If you have the approriate hooks and can give me any requirements I can just make a control in flash for you.
    '05 350Z Roadster
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 07:23 PM
  2. 800mb Flash Drive as bootable drive
    By Tidder in forum General Hardware Discussion
    Last Post: 04-27-2005, 05:40 PM
  3. flash
    By holistic in forum Road Runner
    Last Post: 03-07-2005, 02:46 PM
  4. adding flash
    Last Post: 02-14-2005, 11:25 AM
  5. Compact Flash WIFI?
    By RedGTiVR6 in forum Wireless Communications
    Last Post: 12-30-2004, 04:17 PM
