Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 41
Thread: Flash request please..
  1. #31
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    well you could use the values of the total track time and current track time to place the slider, this would be fine for just viewing where its up to, unsure how you could tap on the slider to move the song to that position
  2. #32
    Jul 2004
    Tampa, FL
    Unsure as in you don't have a hook to move to that position in the song?
    '05 350Z Roadster
    http://www.gregburch.com/
  3. #33
    Feb 2004
    Manchester
    there is a ffwd 5 sec's button and a rw 5 sec's button, maybe this could be used to hook the slider, as it were.. ie.. advance 60 mins.. sends the ffwd command 12 times.
    CdR
    Ok, need some help here.. I have created a sprite, with a circle in it, this circle, now moves form frame 1 (start) to frame 100 (end) of the slider, I thought this would be the best way as each point is a %. Now where would I stick the script and what would it look like.. I could do it in php and vb no probs, but not used to scripting in flash.. can you help. I would need something like..
    TOTALTIME/CURRENTTRACK = SLIDERPERCENT
    Then I'm abit unsure how to call the slider its in a sprite caller 'track' and the circle is called slider.. so would it be something like
    onFrame (70) {
    TOTALTIME/CURRENTTIME = ROUND(SLIDERPOS);
    gotoSceneAndStop("<current scene>",SLIDERPOS);
    ^^^ the current scene is wrong, need to tell it to play the sprite 'track' rather than the current scene.. how would i do that ?
    onFrame (80) {
    gotoSceneAndPlay("<current scene>",70);
    ^^^ above bit is just a timer to repeat the song pos
  4. #34
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I can easily add a "seekto" dynamic command to jump to a clicked position in the format HH:MM:SS or MM:SS .. this is pretty much how I use it in RR anyway (because MPC and Built In player wrk differently) so it would be a matter of sending: fscommand("SEEKTO;02:01","") for instance.. but you'd have to do the calculations for status and for jump position in flash (which may suck) -- the easiest really would be to have the flash clip-off feature (and it could allow for other tricks too).
    Ride Runner RR's Myspace
  5. #35
    Jul 2004
    Tampa, FL
    The calculation in flash would be easy I have written a dozen slider controls 2 of which Macromedia distributes, so you can trust my code . If I get a chance tonight I will play around with a prototype for you, shouldn't take long. I am having problems installing the latest release though...hangs at the end of the installation. That might slow me down.
    '05 350Z Roadster
  6. #36
    guino's Avatar
    Nov 2004
    Toronto, Canada
    the installshield does ?? is it updated ?? :| if you already had a version installed, all you had to do was unzip the binary package over your old files and re-run RRConfig..
  7. #37
    Feb 2004
    Manchester
    ok.. got it to convert to a percent now. using the below code
    Code:
    onFrame (25) {
        TOTALTIME = TRACKTIME.split(":");
        TOTALSECONDS = int(TOTALTIME[1]) + int((TOTALTIME[0]*60));
        CURRENTTIME = CURRENTTRACKTIME.split(":");
        CURRENTSECONDS = int(CURRENTTIME[1]) + int((CURRENTTIME[0]*60));
        SLIDERPO = Math.round((CURRENTSECONDS/TOTALSECONDS)*100);
        slidpos.gotoAndStop(SLIDERPO);
    onFrame (35) {
        gotoSceneAndPlay("<current scene>",25);
    Ok.. got a slider showing the position of the song.. just got to wait for a command to be added to RR, and suss out how to drag the slider around
  8. #38
    guino's Avatar
    Nov 2004
    Toronto, Canada
    ok man.. got the flash clipping to work (that was a pain).. anyway, also got the TODAY label in place... let me know if you need more info then the release thread says...
  9. #39
    Feb 2004
    Manchester
    Hi Guino, had a spare 30 mins, so stuck a video browser flash screen together, just went to test it, and the 'LIST' call takes you to the audio browser. What command would I use to load the video browser ?
    cheers
    CdR
  10. #40
    guino's Avatar
    Nov 2004
    Toronto, Canada
    That would be "LIST" (as well) ... what RR does is check if the current skin is "video_player.skin", if so, it loads the video browser, otherwise audio browser.
    You can load the video browser manually by making the button code something like:
    "LOAD;VIDEO_BROWSER.SKIN" and it will always load the video browser no matter what, but for compatibility reasons I strongly recommend using the standard names "video_player.skin" and "video_browser.skin"...
    Let me know,
    Guino.
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 08:23 PM
  2. 800mb Flash Drive as bootable drive
    By Tidder in forum General Hardware Discussion
    Last Post: 04-27-2005, 06:40 PM
  3. flash
    By holistic in forum Road Runner
    Last Post: 03-07-2005, 03:46 PM
  4. adding flash
    Last Post: 02-14-2005, 12:25 PM
  5. Compact Flash WIFI?
    By RedGTiVR6 in forum Wireless Communications
    Last Post: 12-30-2004, 05:17 PM
