Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 65
Thread: Flash Teaser
  1. #11
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Also, I saw your exit_menu thingy.. to make it show right you need to replace the exit_menu_empty.jpg with exit_menu_off.jpg (in the .skin file) -- but then again since the buttons are not defined in the right position I assume you know it, and just have not edited it yet.. just wanted to point out that it can most definitely be any size you want (like you did).
    I do may have to add just a tiny bit of code to make the touchwheel work with the flash thingy you made on the background...
    Ride Runner RR's Myspace
  2. #12
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    the ipod skin is on hold at the mo.. It was only used the folder to start from hence the name (copy of Ipod) :-) dont worry about any of that, as its all going to be deleted slowly the more flash I do. I only have the radio page to finish on the ipod skin, but I got bored of it as soon as I sussed how to do the basics in flash.. I just couldnt wait to start this one.
    O I see what you mean now about the flash touchwheel.. yeah I only tried that to see if it would work, it didnt so just went back with the normal one.
    CdR
  3. #13
    Variable Bitrate aguila's Avatar
    Jun 2004
    the Netherlands
    Quote Originally Posted by CdRsKuLL
    uploaded.. now with the skin changer, if you have downloaded the one without and dont know how to edit a .ini file, then just download the above one and overwrite the first one :-)
    CdR
    well this looks like quite a new break through. You are certainly setting a new trend. Very nice. Is it hard to edit these flash files? what program do you use?
    MII 6000; 256 MB; lilliput touchscreen; 40GB; bluetooth SE 68i; software still experimenting switched from mediacar to frodopayer, phonecontrol, destinator 3 (NM), and others.
    http://www.mp3car.com/vbulletin/show-off-your-project/31991-audi-tt.html
  4. #14
    Feb 2004
    Manchester
    I'm using Swishmax, once the pennys dropped its quite easy to use.. still finding newe bits on it. I downloaded a 15 day free trial.. so I have about 12 days left before it runs out.. its $99 to buy
    CdR
  5. #15
    FLAC Spaghetti's Avatar
    Jul 2003
    Spagcave, in da UK Today's phrase: J'aime Alizee
    Whoa....$99???!! Might as well get Flash MX.....
  6. #16
    Variable Bitrate MC_Stoo's Avatar
    Jun 2004
    Manchester, UK
    CdR
    I could bring FlashMX to the meet in case you feel the need to *ahem* evaluate the software
    DC UK Forum
  7. #17
    Low Bitrate che420's Avatar
    Feb 2005
    charlottesville VA
    i just have to say thats really good work. i'm a former swishmax pro (moved to flash mx because of work). and i'm very interested on how you got that to work so well so quick. i'm still fumbling around trying to make some original skins and i havent finished one worthy of posting here yet.
    your teaser gave me some damn good ideas....if you ever want to share the swi let me know.
    damn good work
  8. #18
    Feb 2004
    Manchester
    Quote Originally Posted by MC_Stoo
    Thanks m8, I already have it.. just this swish seems a bit more simpler to use. Since i'm only simple and dont have a clue what i'm doing I think its the best option.. anyway its now been bought so I'm hoping to have the skin finished for the meet
    CdR
  9. #19
    Maximum Bitrate CavityCr33p's Avatar
    Jun 2003
    Arkansas
    I used to be great at Swish when it first came out, I need to re-learn it so I could design some stuff.
    2000 Sunfire build 100%, or is it ever really 100%?
  10. #20
    Feb 2004
    Manchester
    ok, had a trial run of the audio in the car today.. it was quite warm, so had the top down for the first time this year :-) couldnt see a dam thing on the screen.. so was pleased that I had stuck the volume up/down at the side, as I didnt really need to look. It looks alot better at night, as you can see it more clearly... anyway I'm nearly happy with the audio flash now, with the changeable backgound and stuff. I want to add some sort of mute flashing thing, or at least some indicator, and after trying it in the car, I want to make the side menu, slide back in if its not used for say 3 or 4 seconds. Anyway below is a page which will give you a idea what it might look like. Of course you can stick what ever background you want.. I've just been playing at the mo.
    http://www.x-digital.addr.com/skin/RRaudio.html
    O yeah.. Gman.. The repeat/shuffle command works, but the indicatiors dont tell the truth, if using the repeat/shuffle they get mixed up, and they start without a variable I think. see demo link above.
    cheers
    CdR
    * edit - added piccy
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 08:23 PM
  2. 800mb Flash Drive as bootable drive
    By Tidder in forum General Hardware Discussion
    Last Post: 04-27-2005, 06:40 PM
  3. flash
    By holistic in forum Road Runner
    Last Post: 03-07-2005, 03:46 PM
  4. Flash + commands/buttons
    By ibrennan in forum Road Runner
    Last Post: 02-16-2005, 11:56 AM
  5. Flash Anyone?
    By guino in forum Road Runner
    Last Post: 02-11-2005, 11:57 AM
