Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
Thread: New Skin: "Spaced Out Remake"
  1. #21
    Newbie Bullseye's Avatar
    Mar 2005
    one question , do u plan a TV Skin ?
  2. #22
    Variable Bitrate garo's Avatar
    Jan 2005
    Milan, Italy
    Yeah, but since I didn't have a TV board, I will do it after more important stuffs
  3. #23
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    About the GPS Browser issue.. it's been fixed.. I'll (hopefully) release it today, even if I need to stick a BETA logo in it..
    Ride Runner RR's Myspace
  4. #24
    Jan 2005
    Milan, Italy
    Wonderful, I'm waiting
    And tomorrow I'll probably release an enhanced version of my skin.
  5. #25
    Constant Bitrate Partybuster's Avatar
    Amsterdam
    what a teamwork, this is going great. If you guys continue like this we will have lots of skins and a superb front end to make us all happy.
  6. #26
    Jan 2005
    Milan, Italy
    Quote Originally Posted by guino
    It works, but unfortunately I almost changed my mind and maybe it's better to link the button to the audio player and not to the audio browser... Mhh, sincerely I'm not sure
  7. #27
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by garo
    You're not blind... I didn't found any method to call the navigate menu with winsock... Is it possible? If someone knew it please tell me
    There's no method in MM to call the main menu.. what you can do instead is make a RR skin menu that is called when pressing the "menu" button (using the LOAD command), then all the options in MM's standard menu can be added as "MM;xxxx" Commands from there.. they should probably be in the fashion: "EXIT||MM;xxxxxx" etc.. and a button to simply Exit can also be done.
  8. #28
    Jan 2005
    Milan, Italy
    Ok, I understand, and this may be the best method to solve the problem. However, for the moment I will use the hotkey, once I will finish the whole skin I will try this solution...
    Tnx Guino!
  9. #29
    Jan 2005
    Milan, Italy
    I released a new version of the skin - 0.2 (look at the first post).
    Just a question: if I open the "exit menu" in my skin, and then press CANCEL, the main screen seems to be not redrawn correctly. Does anyone know why?..
  10. #30
    guino's Avatar
    Nov 2004
    Toronto, Canada
    get the "REDRAW" patch... there was a bug in the last version..
    http://guino.home.insightbb.com/rr.exe
  1. Open Source Skin Editor for RR
    By lbooker in forum Road Runner
    Last Post: 04-16-2007, 01:51 AM
  2. Thoughts on skin design guidelines?
    By Arathranar in forum RR Skins
    Last Post: 06-13-2005, 05:54 PM
  3. Frodoplayer 1.0.9 Skin Released
    By WeeZyFellA in forum FrodoPlayer
    Last Post: 02-13-2005, 10:38 PM
  4. New Skin - Spaced_Out for FrodoPlayer 1.08
    Last Post: 10-17-2004, 09:50 PM
