big YES on that one, except the tooltip field..Originally Posted by Erwin
That is a great idea!!Originally Posted by Phythorian
Ride Runner RR's Myspace
All of them.. look at skin commands.txt to see what each field means.. basically you specify the slider area, then the glow/click area, then the slider style (can be empty), then the pointer file and the size of pointer.. plus the code for what you want it to work with.
the second set of coordinates is for the actual slider. i would either make it the same size or slightly more narrow. have a look at the videoplayer screen and see how that slider is coded.
my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
kuo,
Do you have a fix for the 800X600 mixer skin? It seems the sliders are a bit off.
your right they are, i never even noticed as i never use the mixer
throw a moon
heuvos vin chevos
I have a request for the Clean skin. Could you see if you can get it to work better with FreeDrive. When it runs the controls being at the bottom makes it so i can't see the top of the program. Any ideas? Any help?
Another Novice?
Progress so far <-------*-> 88%
Kenwood MPV5025 with Aux
Via MII10000
512MB Ram
LG Slim DVD\CDRW
Xenarc 700TS
M1ATX
Pharos GPS
SYBA USB2.0 4-port Hub
Bufalo 54Mbs Wirelessb/g PCMCIA card
Now I have the slider working at the bottom of the screen, my only problem is that I can't see it. How can I make the slider visible?
And the day and night settings are not working how do I change that? In the original Skin it works fine.
what can you not see? the slider gif?
throw a moon
heuvos vin chevos
