Page 4 of 29 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 285
Thread: Kuo Skin Release
  1. #31
    Constant Bitrate vortex's Avatar
    Feb 2005
    London, UK
    looks great is there are tv button or can we get psd's to edit it?
  2. #32
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    @kuo
    I've done some improvements with the OSK for applications, you can try it by downloading the PhocoBeta package from the other thread.. if you don't have Phoco, just make sure Phoco.ini doesn't exist and it won't try to use it.
    Ride Runner RR's Myspace
  3. #33
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    thank guino,
    i just tried it and a few things. the sendkey function works much better. only things i see are when you first open roadrunner, and gps was already open in the background, the sendkeys don't work until you click on the app to give it focus. in all other instances the sendkeys work great.
    the osk is also very much improved. couple of things i noticed with it are that the "enter" button does not actually send "enter" to the embedded app. it seems only to exit the osk. maybe my skin is coded wrong. Ascii = 013 Code = 013. Not sure what "Code" is. the other thing is when i use sendkey to open the destination dialogue and then open the osk, it works great, but if i make a button using multiple commands option like this, "SENDKEY;%FE{ENTER}{ENTER}||APPOSK" the main window behind the "enter destination" dialogue has focus.
    thanks for looking at this.
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
  4. #34
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    this isi osme nice work here man! props to you. Any chance to make a VW skin? Thanx
  5. #35
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Yeah, I have to make sure the embbeded App gets focus if it was already opened.. easy thing to do.. on the ENTER key, if you want it to send enter to the application I can add that to it (when it is used for applications that is).
  6. #36
    kuo
    kuo is offline
    Jun 2003
    Greensboro, NC
    thanks guino,
    any idea on why using the multiple command option to pull up the osk doesn't leave focus with the last window opened in the app?
  7. #37
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can try inverting the order of your commands.. "APPOSK||SENDKEY;...."
    This is probably because when you open up the OSK the embeded app looses focus to RR and when opening the OSK, RR throws the focus back onto the application..
  8. #38
    kuo
    kuo is offline
    Jun 2003
    Greensboro, NC
    you're the man guino!
    @vortex. will post up the psd's soon.
  9. #39
    Feb 2005
    London, UK
    Thanks.
  10. #40
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    I really like the skin it looks awesome.
    I have a few of suggests if you don't mind. First when you click the play button to pause the music the button remains as the play symbol. maybe you should change it to the pause symbol "||" and make it flash like the mute button does. Also you might want to move the forward button to where the scan button is. This is just a better flow of the buttons.
    And when you click on the random/repeat button you have the randon and repeat symbols come up on th opposite side in white, you might want to change there color to the same orange you are using. This makes it easier to see that the repeat or random functions are on.
    Other then that its a great skin.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  1. Red highlights for BMV2 Skin done
    By Mad Ad in forum RR Skins
    Last Post: 10-17-2006, 01:41 PM
  2. Sensor skin
    By Erwin in forum RR Skins
    Last Post: 08-28-2005, 03:01 PM
  3. FrankenSkin (first skin)
    By chrishick in forum RR Skins
    Last Post: 06-24-2005, 12:53 PM
  4. Frodoplayer 1.0.9 Skin Released
    By WeeZyFellA in forum FrodoPlayer
    Last Post: 02-13-2005, 11:38 PM
  5. finnaly skin uploaded
    By liquid_smoke in forum ME Archive
    Last Post: 12-31-2003, 10:13 PM
