Results 1 to 10 of 11
Thread: Problem with RR and 640x480 skins.
    May 2005
    Hi all.
    I am having some problems with RR and the Brushed Metal skin in 640x480, it seems like the "buttons" arent calibrated. I have downloaded RR from http://guino.home.insightbb.com/rrbinary.htm, the Brushed Metal skin from http://rmc.pimpedwheels.com/BrushMetalBlue.zip and the 640x480 patch from http://www.dellanave.com/projects/ca...4_4_Update.zip.
    I replaced the files from BrushMetalBlue.zip with the ones from BrushMetal640_4_4_Update.zip but it still is all messed up, is there anything else i have to do to make it work? Tnx in advance, and tnx for a very good dashboard.
    Cheers
    - Bosse
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by bosse
    Hi all.
    Cheers
    - Bosse
    I don't have any idea of what that patch you have has or does, but to get the skin in 640x480, you should do just the below:
    -Delete the current brushmetal skin you have "patched"
    -Download/Install the Brushmetal skin from my site
    -Open the GENERAL.INI file in the skin's folder and change the Showwidth and showheight to 640 and 480 respectively.
    -Load RR normally, it should display the skin in 640x480.
    You can do this with any skin. If you try to patch up skins with files of incorrect size, chances are you'll just screw the skin up.
    Ride Runner RR's Myspace
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The only option to make it look perfect in 640x480 is to resize all images say in photoshop (high quality) then edit all .skin files to set the correct areas.. I think that the update you got is basically for fixing the .skin files ONLY.. there's a whole thread on this, so I'd suggest you search on it a bit..
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Mine displays about 100pixels right and about 100pixels down from top left when I set show to values at 640x480 when using 800x600 skin and setting the top left corner as 0,0 or -100,-100 doesn't move it.
    I would like to move to 640x480 as my Lilli is super sharp at that res and poo at 800x600. And my Insight P4 doesn't do 800x480 - shock horror!
    Any ideas?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    show me your general.ini and a screenshot. This has always worked dated far back to "remediacar". Chances are you just haven't set the screen SIZE correctly.. the positions should be 0,0 (typically).. for size you should have:
    showwidth=640
    showheight=480
    Aug 2004
    On the edge!
    Hi Guino,
    general.ini contents (was called default_general.ini so changed it to try if that helped) and screeny as requested.
    [General]
    OriginalWidth =800
    OriginalHeight=600
    ShowWidth =640
    ShowHeight =480
    XPosition =0
    YPosition =0
    [Gamma]
    ApplyToVideo =False
    ApplyToVisu =False
    AutoSwitch =False
    DayTime =8:00:00 AM
    NightTime =6:00:00 PM
    GammaDayRed =1
    GammaDayGreen =0
    GammaDayBlue =0
    GammaNightRed =-40
    GammaNightGreen =-40
    GammaNightBlue =-40
    Raw Wave
    Jun 2004
    On the beach
    Hmmm, always aligns fine for me here and from what I can tell the general.ini appears ok
    Sounds as if the resolution is set to 800x600 on your PC, not 640x480. I think that may be the problem
    Aug 2004
    On the edge!
    if that was the case it would display RR fine as its an 800x600 skin
    guino's Avatar
    Nov 2004
    Toronto, Canada
    honestly I can almost guarantee you that the general.ini file above is not for the skin you're using .. your screen shot proves it because the size of RR's skin is still 800x600 on it. There's one general.ini file for EACH skin -- and it MUST be in the skin's folder. I also recommend taking off the stupid "hide known extensions" options from your windows folders to be sure you have the right file name.
    Aug 2004
    On the edge!
    sorry Guino, you are right. sorted now thnx
  1. RR not working in 640x480?
    By CavityCr33p in forum Road Runner
    Last Post: 03-22-2005, 12:33 AM
