Results 1 to 6 of 6
Thread: Destinator: Map Monkey Menu command
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Okay I try to remove the bottom menu bar from MM and create Destinator skin in RR for it, but I couldn't find the command for those button.
    I am able to "remove" MM menu bar (by making the graphic 1 pix high.)
    Menu=> I try "MM;Menu" and "Hotkey_CMD|FE_MENU_OPEN", but no go.
    The same for all 6 other buttons, but none of them work. Yes, I enable the plugin support and listen port number according to MM and RR FAQ.
    Now I need the command for these button to put on RR skin.
    Button are from the bottom Left to right
    Menu, Address, Info, Nav/Plan mode toggle, Quick/Short Route toggle, Home, View.
    Any one?
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Constant Bitrate ruairi's Avatar
    Jan 2005
    Spain
    Are you using a firewall like in XP SP2? You'll need to open port 9913 in the firewall, I had this issue with XP SP2.
    Sep 2003
    Beach City, Socal
    Currently I am testing it on my desktop which is Win2K and no firewall install at all.
    BTW, this box is not mean to be connected to the net that is why there is no FW.
    I have to do a netstat to see if that port is open/running or not.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You need to make sure MM is setup for interfacing.. check the FAQ on the GPS settings.. you need to setup the port for connection and enable connections .. (it is OFF by default).
    Ride Runner RR's Myspace
    Mar 2005
    You have to have MM; if front of the hotkey_CMD. Maybe that is part of the problem. All of the below are working for me.
    B02,000,175,090,065,"MM;Hotkey_CMD|FE_ROUTEMODE_TO GGLE",""
    B03,000,240,090,065,"MM;Hotkey_CMD|FE_NAVMODE_TOGG LE",""
    B04,000,305,090,065,"MM;Hotkey_CMD|FE_MENU_ITEM_SE TTINGS",""
    B05,000,370,090,065,"MM;Hotkey_CMD|FE_MENU_ITEM_SW APMAP",""
    B06,000,435,090,065,"MM;QuickFavorite",""
    B07,710,110,156,065,"MM;Hotkey_CMD|FE_GO_HOME",""
    B08,710,175,090,065,"MM;Hotkey_CMD|FE_VIEWMODE_TOG GLE",""
    B09,710,240,090,065,"MM;Hotkey_CMD|FE_COLORMODE_TO GGLE",""
    B10,710,305,090,065,"MM;Hotkey_CMD|FE_VOICEPROMPTS ",""
    B11,710,370,090,065,"MM;Hotkey_CMD|FE_ZOOM_IN",""
    B12,710,435,090,065,"MM;Hotkey_CMD|FE_ZOOM_OUT",""
    Sep 2003
    Beach City, Socal
    guino I did all those.
    chirshick will try those to see what happen.
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 10:27 AM
  2. Replies: 106
    Last Post: 10-20-2008, 09:09 AM
  3. RR Menu to emulate MM Menu button
    By GizmoQ in forum Map Monkey
    Last Post: 09-05-2006, 02:02 PM
  4. Anyone understand Java ? I need help.
    By frodobaggins in forum Software & Software Development
    Last Post: 05-24-2004, 10:53 PM
