When you launch an application, it automatically takes the focus away from RR. So the problem is unlikely to be that Streets&Trips doesn't have the focus, but yet that it requires that you "select" the map (within itself) for the shortcuts to work. I have a copy of 2003 here (I won on a trade-show), so I can probably test it out.. in any case, I can *try* to set the lauched application's as "on focus" right after launching them...
LinkBack URL
About LinkBacks
