Results 11 to 20 of 27
Thread: Working skin for MS Streets and Trips embedded in RR
  1. #11
    Is your web server down? None of the links are working...
  2. #12
    Apr 2005
    San Jose, CA
    Yeah, my wife just informed me, it looks like my T1 is down, after trying to connect via my tampa network and my datacenter network, it seems my downtown office network (X freakin O) is off line. I will just have to wait until it is back up. That is what I get for free rack space
    Sorry guys, it will be obvious when it is back up.
    Chris
    Chris
  3. #13
    Apr 2005
    San Jose, CA
    While I am waiting for XO to get there act together,
    So today, I found out another issue with this skin, it breaks. If I save the open map or open a previously saved map, the application name changes from
    "Maps - Microsoft Streets and Trips" to
    "(whatever I named the file).est - Microsoft Streets and Trips" and then the skin breaks because the app name is wrong. It ends up opening a new instance of Streets.exe, hiding the other one under RR and generally making things strange.
    When I get a minute, I will test it with the class name and windspector to see if that works. I'll update the skin if I can make it work better.
    I also decided my amber is to yellow and needs more orange to match my car.
    Chris
  4. #14
    Apr 2005
    San Jose, CA
    Well that worked, I will update the skin when I can get to my server again but in the mean time, if you already have it, change all occurrences of (menu.skin, streets.skin and exit_menu.skin)
    Map - Microsoft Streets and Trips
    to
    !Afx:400000:8:0:0:103c6
    and you will be able to use saved maps normally.
    Chris
  5. #15
    Apr 2005
    San Jose, CA
    Ok, the links are back up.
    Chris
  6. #16
    Apr 2005
    San Jose, CA
    Quote Originally Posted by HyperSprite
    to
    Chris
    Scratch that, the class changes after restarting the computer, the class is now !Afx:400000:8:0:0:1140727 and the app starts but not embedded. So it's back to Map - Microsoft Streets and Trips for now.
  7. #17
    May 2005
    UK
    AGPS ? - Can you import your own wav files ?
    cheap web hosting ...
    http://www.swanseahost.co.uk (Cheap plug lol)
  8. #18
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    Great job! That was one of the best tutorials I've read in awhile
  9. #19
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by ctwizard
    AGPS only works with MAPPOINT (as far as I know this is in the author's page). wav files should be changable if they're in the install folders, otherwise, I highly doubt it.
    Ride Runner RR's Myspace
  10. #20
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If this part of the Window title is ALWAYS present:
    " - Microsoft Streets and Trips", then you should be able to just use that..
    What I mean is: it is not necessary to use the ENTIRE window name to match for embbeding -- it just makes it more precise (which can be too precise at times like this). The same goes for the class name.
  1. Microsoft streets and trips with GPS
    By carchrism5 in forum GPS
    Last Post: 04-19-2007, 08:53 PM
  2. No initial focus on embedded MS Streets
    By HyperSprite in forum RR Skins
    Last Post: 06-09-2005, 01:41 PM
  3. Front end for streets and trips
    By jay_tu in forum Newbie
    Last Post: 05-13-2005, 06:07 PM
  4. Streets & Trips GPS Functionality?
    By Vchat20 in forum GPS
    Last Post: 02-27-2005, 10:42 PM
  5. Streets & Trips 2004 Autostart GPS
    By Jailer in forum GPS
    Last Post: 10-22-2004, 03:22 PM
