Dang.. you really put some work on it... I guess anybody not willing to spend the $$$ for a high-end GPS software could get S&T instead (~$40 last time I checked).
Regarding closing the application, RR will not "close" it by default when exiting the front-end, BUT if you go back into RR and launch the GPS again, RR will use the running application that was "hidden". You can adda "CLOSE" command to make it actually close out of the application when needed. Optionally, you can make your "exit" command (on the exit menu or wherever you exit from RR):
"CLOSEWINDOW;Map - Microsoft Streets & Trips||EXIT"
This will close the "hidden" application in case you left it open. It won't do anything wrong if S&T was not open.
LinkBack URL
About LinkBacks
