Results 1 to 10 of 11
Thread: alpine skin questions
    Low Bitrate hakhawk's Avatar
    Apr 2005
    newborough, VIC, AUS
    ok, i have been using bfm skin for a while now, and saw the alpine one and decided to download and try it. looks great, but a couple of things, i cant get the search function to work, i changed the enter in the skin files to searchlist and searchfiles, but still no go. and, how can i have the music player window come up when it starts, not the main menu.
    FLAC J187's Avatar
    Nov 2004
    Boston
    Did you change the Playlist.Skin "Enter" to "Searchlist" and the browser.skin "Enter" to "searchfiles" or did you maybe mix them up? Also, make sure you included the "" marks - a common mistake. As far as starting to the audio player, simple. Use RRConfig and set the start command to execute box to Audio - no ""
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Apr 2005
    ok, i got the start as audio bit working, thanks for that, but search still wont work. ok, i goto music player, then click list, then click search edit button, type in word up top, click search, it kicks me bak to list.
    i have search_playlist and search_browser .skin files. with the enter replaced properly.
    im using the alpine skin from guinos site. i really want to switch to this skin, but i want search working.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    IF you changed the skin codes: sounds like you're just using an old version of RR.
    Try this one: http://guino.home.insightbb.com/rr.exe
    Ride Runner RR's Myspace
    FLAC J187's Avatar
    Nov 2004
    Boston
    Sounds like you are not searching your whole music directory. I prefer the search to look in my whole music directory for all my searches.
    Do this.
    1. get skin editor from Guiino's site.
    2. Open editor
    3. Open The skin you are trying to change in editor
    4. Under screens, choose Search_Broser.SKin
    5. Double click the button for Search
    6. copy and past this in the text box that says Code "!BROWSE||SEARCHFILES" - include ""s.
    7. Save Skin
    8. Reload RR AND/OR Reload skin.
    9. When you click search it will query your whole music folder for a match regardless of what is open below.
    Please help.
    Apr 2005
    ok, this is annoying, whenever i press the search button on the search_paylist and Search_browser skins, it kicks me back to revious screen without searching at all. and i updated to that new rr.exe, thanks guino, nice splash screen on it too. even if i make the list button on audio_player skin to "searchlist" it still goes into the audio browser skin. whats going on?? my other skins search fine, but they bring up the osk skin, this one brings up its own weird one. can anyone help me?? im gonna go nuts.
    Apr 2005
    hahahahahahaha, i SUCK. i just found out my problem, bacause im not testing this on the car, i have a copy of rr on desktop, then i copied it to my d: drive, and have been editing the skin in the d: folder, but it was still linking to the skins folder on the desktop. omg, i didnt even see it. ok, now im gonna try again, bear with me here.
    ::EDIT::
    ok, it works now, thankyou both very much guys, its all good, now i can fix up a few cosmetic things on it easier now, thanks to the skin editor aswell.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    did you by any chance "mix" some skin files on your skin ? This is what happens (on the latest versions of RR):
    You press "list" then "search edit" and it brings you the screen to search files with the small OSK on the top and the text box -- you should see the files listed below.. when you execute "searchfiles" in that screen (search_browser.skin) it should use the text on the same screen and show the results right on the same screen -- just tested it. When you click "LIST" on the right side of that screen, it should show you your playlist and let you search it, then show the results on the same screen -- just tested it too. It is important that the file names for the skins are: search_browser.skin and search_playlist.skin ... other than that, it should work fine unless you screwed up something with your skin files..
    Attached are what I have on my alpine amber (that works fine).. this is the 800x600 version... try them out or compare it with yours..
    Attached Files Attached Files
    Apr 2005
    ok, just read my previous post, so in the end, all i modified, was the "enter" to "searchlist" and "searchfiles" in their respective skin files. i feel so stupid sometimes. such a simple mistake, lol. and, thanks again.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    sorry, I was replying right when you posted it, so I didn't see it in time.. glad you got it worked out.
  1. MediaCar Alpine Skin
    By more mods in forum MediaCar
    Last Post: 05-05-2007, 06:14 PM
  2. Alpine or automobile make skin?
    By kameleon in forum FrodoPlayer
    Last Post: 06-13-2005, 10:13 PM
  3. Photoshop files for Alpine skin ?????
    By tolisn in forum RR Skins
    Last Post: 04-07-2005, 12:07 AM
  4. Problems with Alpine Skin
    By superbowl in forum Road Runner
    Last Post: 01-29-2005, 11:02 AM
  5. Problems with Alpine skin
    By chuckster in forum Road Runner
    Last Post: 01-27-2005, 10:22 PM
