Page 10 of 22 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 212
Thread: iRunner
  1. #91
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    Hang in there.. updates are coming
  2. #92
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by DiNASTY
    Your logo / clock has worked well always, I have installed again now MM and the analogical part of the clock works, only the digitals remains always to 00:00
    Some possible suggestion?
    Mauri
  3. #93
    Mar 2005
    Concord, California
    make sure this label is in your menu.skin file:
    L,0,0,0,0,,,,,,"TIME",
    I will also be redoing the clocks for the update
  4. #94
    FLAC mauri's Avatar
    Jan 2004
    Yes, the label in "menu.skin" written ok.
    Mauri
  5. #95
    Constant Bitrate m-ruiter's Avatar
    Jul 2005
    Kortenhoef
    Mine worked great until the last update of Road Runner.
    I saw in the LS 3.0 skin thread also somebody with the clock error.
    I guess RR has a bug ?
    I can't wait until the next update op iRunner.
    The 2 skins i have in user are
    1. iRunner
    2. LS 3.0
    LS just to show somebody it's skinnable. iRunner as default because it's the best skin arround at the moment. (hope it will stay to)
    Is weather also implemented in the update version ? (Use it just because its funny and handy dandy)
  6. #96
    FLAC mauri's Avatar
    Jan 2004
    True, I think both a bug of RR last release the problem of the clock.
    It needs to make to know to Guino...
    Mauri
  7. #97
    May 2005
    with the last version of RR, irunner it's not running correctly. I installed an old version of RR.
    The info of the song don't show.
    Renault Megane Coupé Cabriolet
    P3 550 mhz 256 mb RAM 15 gb hd, dvd.
    gps handsfree parrot ck3300
    windows xp sp2
    road runner
    map monkey and viamichelin mapsonic
    Touchscreen 7" fully motorized in-dash
  8. #98
    Mar 2005
    Concord, California
    Thanks for pointing that out... guino has a new version that fixes this which should be out in the next release.
    In the meantime, I have been combing through iRunner and making changes here and there. I would like to make some major graphic/function changes but it could take some time. Would you all have me make the changes or add more screens to the current iRunner?
    updates in progress:
    Clocks (with direction indicators) will look similar to these
    Menu re-organized
    Background changes
    iG Support
    Phoco
    more FD support
  9. #99
    Jul 2005
    DiNASTY,
    I have been using this for a couple of weeks and LOVE it! I dont know if it helps but I personally would love to see :-
    1) A Standby option
    2) External Apps/Web
    3) Phone Control
    4) GPS Customisation :-
    I use Navigator and couldnt see how the control buttons interface to the GPS software? Did I miss something when I looked at the skin files (Im new to skin structure). If I cant customise the GPS buttons, is it possible to remove them so Navigator can consume the space they use?
    I love IRunner though
    Rgds and thanks
    Ant
  10. #100
    Aug 2005
    Not sure if anyone else agrees with this, but...
    I'd like to have the flexibility of seeing current track playing AND having the cosmetic appearance of the car logo/clock screen. If the logo/clock screen is all in Flash, could you have a button on there to get Flash to 'cycle' say every 10 seconds from the logo/clock to the current track playing?
    I do quite long journeys where before I set off I create a playlist and then hit "Play" just once. Then I often return to the logo/clock screen for the journey.
    cheers
    aiml27
