Page 11 of 22 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 101 to 110 of 212
Thread: iRunner
  1. #101
    Aug 2005
    Sorry, forgot to say:
    DINASTY you're the chief! The iRunner skin is by far the cleanest-looking RR skin out there. I love the audible and visual button-press stuff in Flash.
    Also, yeh, iGuidance integration is a must-have! I modified the External GPS.skin and JPGs to include zoom in/out, set destination, cancel route, etc, etc along the left-hand side, and added music controls and info to the bottom. This works really nice for me but I don't have your talent for graphical design ;-)
    aiml27
  2. #102
    Nov 2004
    I like this skin so mutch, but i can't get it to work on 640x480 ... this can be done with all the other skins of RR, but not with this one ? Is there any way to do this ? Thnx ....
  3. #103
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    hrmm... It seems to work on my desktop with just setting the ShowWidth/Height in the general.ini file... not too sure??
  4. #104
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Acid burn
    You should tell us HOW you tried to run it at 640x480 and WHAT PROBLEM you encountered. This way we can try to help you.. I have just tried this skin at 640x480 and it worked perfectly.
    Ride Runner RR's Myspace
  5. #105
    Nov 2004
    I altered the general.ini file to 640 and 480 .. that's all ..
  6. #106
    Aug 2005
    DiNASTY
    Question on DVD/Video playback. Since your fantastic skin is Flash-based in many ways, I can't see anywhere that tells me what player is used for each. Now I'm assuming the 'DVD' button is for direct playback from a DVD player, and the 'Film reel' button is for video file playback, e.g. AVI or VOB on your hard disk, correct?
    With the settings in RR, am I correct in thinking the skin's 'DVD' button drives MediaPlayer Classic, and the 'film reel' uses the "External DVD Player" if RR is configured this way?
  7. #107
    guino's Avatar
    Nov 2004
    Toronto, Canada
    And the problem you encountered was ??????? I mean, you said it doesn't work, but didn't say anything about the problem or result when trying to run the skin at 640x480... as I said, I tried it and it worked fine.. if you edited general.ini, chances are you changed the wrong numbers to 640 and 480 (like the original width/height instead of the SHOW width and height).
  8. #108
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by aiml27
    The Film button loads the video player (AVI etc) using whatever player you set in RRConfig (MPC or Built-in). The DVD button works if you use Media PLayer classic for DVDs and should also work if you make an "external_dvd.skin" to be loaded with your DVD application.
  9. #109
    Newbie zieak's Avatar
    Aug 2005
    Petersburg, Alaska
    Suzuki
    Can I get a little love for the Suzuki owners? (In the form of a logo clock preferably).
  10. #110
    Mar 2005
    Concord, California
    Guino,
    I'd like to get your help on improving iRunner for the next update. I'm trying to improve the speed by deleting some of the sprites when they are not in use. The only problem is how to have RR trigger them to reload.
    You mentioned a while back that "It should be possible to set and poll the various states of flash movies by using the custom indicators feature." I know how to monitor labels in flash, but I'm not sure how to go about monitoring/polling the true/false state of an indicator.
    This would also allow me to improve other stuff too so I'm all ears
    BTW. Suzuki clock and new screenies coming soon
