Dunno about the screenies, but that Mezzanine album is great.![]()
This looks very nice. Clean and sylish like OS X. I'm a big fan of the Aqua look. Can't wait for the release. Hopefully it will run fine on my PII 600.
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
PIIHopefully it will run fine on my PII 600I doubt it..
guino,
The "|" are not a problem for the double commands because for every button press event in flash, I can send as many fscommands as I want. I narrowed the issue down to the commands that you can't split up into separate fscommands such as the MM hotkey ones. Also, I get the same problem with "\" slashes when doing LOAD commands from flash so I think I might take you up on your offer at least to find a solution to the problem.![]()
So far I know that those characters offer issues: "!", "|" and "\", can you think/try any others so I can add support for them as well ? This also would help me define how to go around the issue.. if you add the debugmode=true to RR.INI you should be able to see what RR is receiving from flash when using those commands...
Ride Runner RR's Myspace
The only important ones that I can think of are the ones you mentioned, however here is a list of fscommands with the corresponding RR debug in case you need any others.![]()
fscommand("/",""); ------ Executing: /
fscommand("(",""); ------ Executing: (
fscommand(")",""); ------ Executing: )
fscommand("-",""); ------ Executing: -
fscommand("_",""); ------ Executing: _
fscommand("=",""); ------ Executing: =
fscommand(";",""); ------ Executing: ;
fscommand(":",""); ------ Executing: :
fscommand("&",""); ------ Executing: &
fscommand("#",""); ------ Executing: #
fscommand("!",""); ------ Executing:
fscommand("|",""); ------ Executing: %7c
fscommand("||",""); ------ Executing: %7c%7c
fscommand("?",""); ------ Executing: ?
fscommand("*",""); ------ Executing: *
fscommand("~",""); ------ Executing: ~
fscommand("%",""); ------ Executing: %25
fscommand("@",""); ------ Executing: @
fscommand("+",""); ------ Executing: +
fscommand(">",""); ------ Executing: %3e
fscommand("[",""); ------ Executing: %5b
fscommand("]",""); ------ Executing: %5d
fscommand("{",""); ------ Executing: %7b
fscommand("}",""); ------ Executing: %7d
- fscommand("RUN;C:\Program Files\Road Runner\rrconfig.exe","");
Executing: RUN;C:Program%20FilesRoad%20Runner%0drconfig.exe
Shell: "C:Program%20FilesRoad%20Runner%0drconfig.exe"
- fscommand("RUN;C:\Program Files\Road Runner\RRCONFIG.EXE","");
Executing: RUN;C:Program%20FilesRoad%20RunnerRRCONFIG.EXE
Shell: "C:Program%20FilesRoad%20RunnerRRCONFIG.EXE"
Cool man, thanks.. You have no idea how much time you saved me.. (I don't have FlashMX installed currently)... I'll make RR automatically interpret some of those codes ... but I would like you to try using "\!" instead of just "!" and "\\" instead of just "\" to see how they execute.. those two have to be done inside flash because I don't think RR receives anything for them... also, "\ " (backslach+space) may work in place of " " (space)...Originally Posted by DiNASTY
Try this for instance:
fscommand("RUN;C:\\Program\ Files\\Road\ Runner\\RRCONFIG.EXE","");
Your right, It doesn't look like it read much of anything.I don't think RR receives anything for them...
fscommand("\!",""); ----- Executing:
fscommand("\\",""); ----- Executing: %5c
fscommand("\ ",""); ----- Executing:
fscommand(" ",""); ----- Executing:
fscommand("!SELECT+",""); ----- Executing: SELECT+
fscommand("\!SELECT+",""); ----- Executing: SELECT+
Executing: RUN;C:%5cProgram%20Files%5cRoad%20Runner%5cRRCONFI G.EXE
yeah, guess I have more work than I thought.. anyway, I'll look into this shortly. I believe we may have to add something special for "!" like "@@" or something like that. I'll post a "patch" for you to try out shortly.. in the meantime if you can try: fscommand("!!",""); I'd appreciate it.. for now I can tell you that when using "\" you'llhave to use "\\" from flash -- all other characters will be used normally (when I'm done)... then we need to do something for the "!" ...
Here's something for you to try:
http://guino.mpug.co.uk/rr.exe
It should accept all the characters that were giving you trouble.. also, @@ can be used as ! (i.e. "@@SELECT+") ... remember to use \\ instead of single \ ... also, you can execute commands in "repeat" mode by setting the parameter to "asrepeat" and simulate mouse Down and Up events using "buttonup" and "buttondown" as paramter...
to execute "!SELECT+" either: fscommand("@@SELECT+","") or fscommand("SELECT+","ASREPEAT")...
the up/down events are usefull if your flash object by any means "repeats" presses at random... i.e. fscommand("NEXT","BUTTONDOWN") -- starts fast forwarding the song until a fscommand("NEXT","BUTTONUP") is executed...
Thanks for the support guino, everything works perfect![]()
