Page 8 of 22 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 212
Thread: iRunner
  1. #71
    Newbie Bradipo's Avatar
    Apr 2005
    Italy
    Quote Originally Posted by Bradipo
    SsangYong logo clock, please ...
    Thank you very much!
    ... Your skin is very nice ...
  2. #72
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    is it just me... or does the RR config button not work?
    The RR config button does a "RUN;C:\Program Files\Road Runner\RRConfig.exe" command so i'm guessing you have rr installed in a different location. I can make a patch for you if you really need it.
    @liquid smoke: better VW logo added.
    btw, I will be starting a new skin soon (no flash this time) .... well maybe a little....
  3. #73
    Nov 2004
    St Louis
    Quote Originally Posted by DiNASTY
    Here, try this one out...
    You must add the following to whatever .skin you will be using while driving:
    • L,0,0,0,0,,,,,,"GPSSPD",
    • F,0,0,10,10,"SSV.swf"
    Add this to your skin folder
    Also, Map Monkey must be running in order for this to work.
    Remember to buckle up
    DiNASTY, I have a request for a customized "SSV.swf." I tried the above and it does exactly what you said except for one small detail - it kicks in and out at 70MPH.
    I need one customized for my car. I am running a convertable with lts of wind noise, so I need step increases of 20% at 30MPH, 50MPH, and 70MPH. Is this doable?
  4. #74
    Nov 2004
    St Louis
    BUMP
    Quote Originally Posted by GizmoQ
  5. #75
    May 2005
    is finished this skin? i use it and i must press doubled click in control, info, menu, etc.. more better if i would can use it this only one click
    Renault Megane Coupé Cabriolet
    P3 550 mhz 256 mb RAM 15 gb hd, dvd.
    gps handsfree parrot ck3300
    windows xp sp2
    road runner
    map monkey and viamichelin mapsonic
    Touchscreen 7" fully motorized in-dash
  6. #76
    Mar 2005
    Concord, California
    BUMP
    Sorry bout that GizmoQ, I've been busy lately. I tried to make one that changes 20% at those speeds, but it just doesn't seem to work. You can try and add the following three files to your skin, all on the same screen and maybe that will work.
    30-50-70
    If it doesn't, here is one that changes 45% volume at 50mph.
    @xuri the double clicking is a focus issue between RR and my flash menu. I never noticed it while skinning iRunner cuz 1) I don't have a touchscreen and 2) I found that mouse dragging returns focus to the flash object and it must have slipped by me. I would ask guino if anything can be done.
    Just wondering.... does anyone use iRunner as their main skin? If so... could you post a pic of it running in your car? I never got to see it in action
  7. #77
    May 2005
    yes i use it as my main skin... i had to fill in the pages that you did not make with others from other skins like i use map point for gps and the radio... the phone control and dvd i don't use so i would love to remove them somehow and replace with tv and xm or even better to have matching skins for all of that... if you could find the time someday as this is the best skin i have ever used.... I will take a video of it in action tonight when you can see it working.
  8. #78
    Constant Bitrate vortex's Avatar
    Feb 2005
    London, UK
    I also got the double click problem when using touchscreen very annoyying is it possible to fix this problem?
  9. #79
    Nov 2004
    St Louis
    30-50-70
    Thanx I'll give it a try
  10. #80
    Mar 2005
    Concord, California
    You can start by going into the Buttons folder and deleting "button2.swf" and "button5.swf". Button8 is an XM button but needs to be renamed to button2/5 depending on where you want it on the menu. I’ll get to work on the screens and the TV button.
