Results 1 to 4 of 4
Thread: Skinning questions - topic
    Jul 2004
    NL, Druten
    And i'm the first one with a question..
    I'm trying to build my own skin.. Everything works well on my desktop, in the car it seems some labels are frozen. The tagtitle, tagartist, volume doesn't change. When I use puppetmaster to play the next song or change volume, the screen DOES change. WHY? I just can't figure out. It's not a performance issue. My carpc comes with P4@2600, 1GB, ATI 9200 that's more then my desktop. (almost ) Here's the code I generated with RR Skin Editor.
    What is it that I do wrong people??
    Code:
    MEDIACAR Skin
    MEDIACAR "audioplayer"skinskinskinskinskinskinskinskinskinskinskinskinskin skin
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B,500,0,150,100,"VISU",
    B,300,500,100,150,"VOL-",
    B07,400,500,100,100,"VOL+","Volume+"
    B09,0,500,150,100,"PREV","Prev/FW"
    B10,500,500,150,100,"PLAY","Play"
    B11,650,500,150,100,"NEXT","Next/FF"
    B13,150,500,150,100,"STOP","Stop"
    B16,300,0,200,100,"LOAD;Audio_List.skin",
    B21,0,0,150,100,"EXIT","Exit"
    B,650,0,150,100,"GPS",
    B,150,0,150,100,"MIXER",
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L,74,272,400,30,192,192,192,20,"Decker:B","TAGARTIST","LEFT"
    L,74,225,600,40,255,255,255,28,"Decker:B","TAGTITLE","LEFT"
    L08,232,430,300,30,192,192,192,16,"Decker:B","PLAYLIST","Playlist"
    L05,75,188,100,30,192,192,192,14,"Decker:B","KBPS","Track bitrate"
    L06,213,188,100,30,192,192,192,14,"Decker:B","KHZ","Track freq"
    L,233,339,200,20,255,255,255,18,"Decker:B","TAGYEAR",
    L,233,365,200,20,255,255,255,18,"Decker:B","TAGGENRE",
    L07,660,357,50,30,255,255,255,16,"Decker:B","VOLUME","LEFT"
    L08,351,188,75,30,192,192,192,14,"Decker:B","STATUS","Status"
    L02,471,187,80,30,192,192,192,14,"Decker:B","CURRENTTRACKTIME","Current track time"
    L01,594,187,80,30,192,192,192,14,"Decker:B","TRACKTIME","Total Track Time"
    L,600,430,50,30,192,192,192,16,"Decker:B","=CPU","RIGHT"
    L,600,393,50,30,192,192,192,16,"Decker:B","=Case",
    L,600,357,50,30,192,192,192,16,"Decker:B","=Vol","RIGHT"
    L,233,393,300,30,255,255,255,18,"Decker","TAGALBUM","SCROLL-LEFT"
    L08,660,393,52,30,255,255,255,16,"Decker:B","MbM1","0.0C"
    L08,660,430,52,30,255,255,255,16,"Decker:B","MbM2","0.0C"
    /, J, x, y, w, h
    J01,74,310,150,150
    END
    Oh, for the one's interessed.. I use a simple screen (no list). playlist goes to next screen. Only labels and some small buttons (text).
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    TAGXXXX labels only work if ID3 tags are enabled in RRConfig. Also, make sure those lines don't end with: , (put a "" on the tooltip field if needed).
    Other than that, you can post your jpgs+skin file so I can try it (if it doesn't work).
    Ride Runner RR's Myspace
    Jul 2004
    NL, Druten
    Reinstall of RR did solve the problem.. thanxs anyway
    Jul 2004
    NL, Druten
    Small update.. This accures when "hidden mouse" is on. Even on my fresh installed pc.
  1. questions and more questions
    By cortinaking in forum Newbie
    Last Post: 06-16-2005, 02:02 PM
  2. Replies: 6
    Last Post: 05-25-2005, 11:53 AM
  3. Some simple questions (skinning and location)
    By Geking in forum FrodoPlayer
    Last Post: 01-24-2005, 11:57 PM
  4. Skinning Questions with VB6
    By (6) in forum Software & Software Development
    Last Post: 10-19-2004, 02:05 PM
  5. Few Skinning Questions..
    By [iG] in forum FrodoPlayer
    Last Post: 07-02-2004, 06:58 AM
