Results 1 to 10 of 15
Thread: Skullster Skin.. Please help me finish this skin
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    ok.. first off this is a module skin.. which means I've done most of the work so you have a basic layout, and anything in the middle can be changed.
    I havent done much on this, but you will see how easy it is to add your own stuff.
    things I have done..
    Main menu ( password is 1111 ) you can change this in menu.txt
    Audio
    Audio Browser
    Video
    Video Browser
    GPS (sort of)
    Exit
    Skin Browser
    I know theres loads to do, but if you feel like you can help then please do.
    Now this skin uses freedrive as well, infact gps is on all pages. You will need to edit the sdk.ini file in freedrive to look something like this;
    FDSPEED=
    FDSATS=RoadRunner
    FDSATIND=RoadRunner
    FDETA=RoadRunner
    FDETR=RoadRunner
    FDHEAD=
    FDROAD=RoadRunner
    FDLONG=
    FDLAT=
    FDALT=
    FDTIME=
    FDDATE=
    FDEND=
    FDDIST=
    FDUNITS=
    FDMAN=
    FDNEXTMAN=
    FDNEXTSTREET=
    FDNEXTMANDIST=
    FDMANFULL=RoadRunner
    FDCAMS=
    Now... as I said everything is module.. so in the skin folder you will find a templete folder, in this are some blank images and also a blank.skin this holds all the buttons/info for the blank skin, all you need to do is add the middle :-)
    There is a little flash in it, mainly the security page and the volume bar at the side.
    Security page..
    This can be configured by editing the menu.txt
    &password=1111&
    &exit=EXIT&
    &numberofattempts=3&
    //password - Just change the password to whatever you want (0-9)
    //exit - Command excuted when password is wrong
    //numberofattempts - how may times your allows to get it wrong before above command is used
    you can set your password / number of attempts / action if wrong
    If you dont want to use this, just open up RRconfig and put something like AUDIO in the Start command to execute box
    Grab the Skullster 0.1 version from HERE
    Please let me know what you think :-)
    CdR
    Feb 2004
    Manchester
    o btw you will also need the LCD2 font installed on your system for it all to look nice
    attached
    CdR
    Attached Files Attached Files
    mox
    mox is offline
    Constant Bitrate mox's Avatar
    Nov 2004
    The Netherlands
    Awesome stuff -- I envy you (and other skinners) for your graphics skills!
    CarPC status: HW all done, SW needs tweaked.
    Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
    Software: RR, MM/FD
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I just added some prevention against displaying those "CENTER"/"RIGHT" labels when when FD isn't running.. will be on next release..
    Ride Runner RR's Myspace
    Feb 2004
    Manchester
    your a good man :-) Will be adding more modules as I go along
    Thanks M8
    CdR
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    love this skin!
    Variable Bitrate Viscouse's Avatar
    Jul 2005
    Motor City
    I love the volume button. Out of the way, yet still a design element on every page that's not intrusive or "Oh there's the volume button".
    I should add that I actually really like the module idea. I love the idea of static buttons on every page, and info that shows on every page.
    Can't wait to see what's next!
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
    Maximum Bitrate MoFo's Avatar
    May 2004
    TX
    Hey CDRSkull. is this possible? instead of having album art..have a little minimap:
    Photochop:
    May 2004
    TX
    or if a minimap is not possible..how about an arrow and distance to next turn:
    photochop:
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The second one should be possible with a little flash or extra integration... I haven't found time to test this feature (already implemented) for MM... but there's some bug in MM's distance information (or so I hear).. I believe Arathranar is working on something to allow displaying the map in different screens... for FreeDrive you can easily do that by doing the same of the GPS screen on the audio player screen (embed&cut window) -- this would display FD's menus though.. and it may not "FIT" in the small space correctly..
  1. Open Source Skin Editor for RR
    By lbooker in forum Road Runner
    Last Post: 04-16-2007, 02:51 AM
  2. Who wishes to finish this skin?
    By mick-uk in forum RR Skins
    Last Post: 06-16-2005, 06:31 PM
  3. Frodoplayer 1.0.9 Skin Released
    By WeeZyFellA in forum FrodoPlayer
    Last Post: 02-13-2005, 11:38 PM
  4. New Skin - Spaced_Out for FrodoPlayer 1.08
    Last Post: 10-17-2004, 10:50 PM
  5. Anyone want to finish my skin?
    By Rireal in forum Media Engine
    Last Post: 09-01-2004, 02:55 PM
