Results 1 to 5 of 5
Thread: Photoshop skinning question
    Maximum Bitrate wysocki's Avatar
    Mar 2004
    Los Angeles Area
    I'm creating a skin in PS/CS2 and I have each button on it's own layer (so I can move them around easily). I've setup a layer effect of "outer glow" on the buttons that I want to show when I save the xxx_ON.jpg image. The problem is that whenever I edit the psd, I have to change every layer's effect manually in order to be able to save the ON and OFF versions of the jpg. How do you pro skinners handle this in PS? Is there some sort of global style change command?
    Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Just link all of the layers you want to change effect together, then select one of them, change the layer to what you want, hit "Copy Layer style", then hit "Paste Layer Style to Linked" ... at least that's how I do it...
    Ride Runner RR's Myspace
    Mar 2004
    Los Angeles Area
    Can I have multiple links for different purposes? Right now I have three layers for each button: the actual button image, the icon on top of the image, the text associated with the icon. I link the three together so that when I move the button, then the text and icon follow it. Are most skinners just merging the icons/text onto the button in the psd?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Well, I make links while editing, then when I'm done, I make the links grouping the effects I want to handle.. A lot of people just save PSDs with the different ON/OFF/DOWN effects (3 PSDs) just so they can move/link things at will... I don't know of any way to save/restore any linked objects etc.. You can group objects together for easy linking but that's as far as I know ...
    PS: I am no PS expert either..
    Constant Bitrate holistic's Avatar
    Feb 2005
    Denmark
    follow theese 3 screens and u will be there
    Food goes in here..... that's right ... mmmmm
  1. Skinning question
    By ayclens in forum FP Skins
    Last Post: 07-28-2005, 11:57 AM
  2. Noob Skinning Question
    By tom2112 in forum FrodoPlayer
    Last Post: 02-22-2005, 05:40 PM
  3. Skinning Question.
    By mick-uk in forum Map Monkey
    Last Post: 01-03-2005, 12:20 PM
  4. Button question for skinning
    By gambit32 in forum FrodoPlayer
    Last Post: 09-27-2004, 09:04 AM
  5. Software Skinning Question
    By veetid in forum Software & Software Development
    Last Post: 07-22-2004, 01:48 PM
