Results 1 to 10 of 10
Thread: Is this possible? Button to load playlist
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    I'm not sure this is possible but what i'd like to do is assign buttons on the Zots skin to load specific playlists or music folders into RR. The button would essentially have to do the following tasks
    -clear current playlist
    -load defined playlist (one playlist per button)
    is this possible. I looked in skincommands.txt but i couldnt figure out if it was possible. I have already created my buttons and edited the skin... now i just need to know the command to accomplish this.
    Variable Bitrate Erwin's Avatar
    Mar 2005
    I don't know wether RR supports it, but it is a great Idea!
    Hardware: Via Epia M10000, 512MB DDR RAM, 3,5" 40 Gig HD, slimline DVD-ROM & CD-R/RW, M1-ATX (PSU).
    Software: Roadrunner, Mapmonkey/Freedrive
    My Car PC project
    FD & MM voices
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Use the RUNQ command to run winamp along with the playlist path of the .M3U to load, then use "RELOADLIST" to make it effective.
    "RUNQ;C:\Progra~1\Winamp\Winamp.exe|D:\Music\MyLis t.M3U||RELOADLIST"
    Ride Runner RR's Myspace
    Woodbridge, VA
    Blog Entries
    55
    you're the man guino! The more i learn about RR the sweeter it gets!
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    this is very close to an idea i had a LONG time ago about how to load music dir or playlist up like it was a huge cd changer.
    Is there anway we can get this to work with only one button push? It basicly just steps through each playlist as if it were a track.
    Speaking of playlist, in RR there is a save list button to save a playlist, how do you load that playlist back up? After i save it I dont see it anywhere.
    Woodbridge, VA
    Blog Entries
    55
    i've attached a pic of my zots screen. The circled buttons each load a different playlist. I only wish i knew how to edit the .psd to label each button. Not sure if ur talkin about doin it the same way but i've tested it and it works fine.
    Raw Wave
    Jun 2004
    On the beach
    Label it using the RR Skineditor, saves messing about then.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by liquid_smoke
    You can use SwitchButton and SetLabel for that..
    In ExecTBL.INI:
    "LOADROCK","RUNQ;<Path>\Winamp.exe <Path>\Rock.m3u||RELOADLIST"
    "LOADPOP","RUNQ;<Path>\Winamp.exe <Path>\Pop.m3u||RELOADLIST"
    "LOADRAP","RUNQ;<Path>\Winamp.exe <Path>\Rap.m3u||RELOADLIST"
    Then on define a custom label and the button as:
    L,xxx,xxx...,"!PLAYLIST","Rock"
    B1,xxx,xxx....,"LOADROCK||SETLABEL;!PLAYLIST;Pop|| SWITCHBUTTON;1>>LOADPOP||SETLABEL;!PLAYLIST;Rap||S WITCHBUTTON;1>>LOADRAP||SETLABEL;!PLAYLIST;Rock||S WITCHBUTTON;1",""
    Your playlists are saved wherever you setup in RRConfig... as long as you set it a place you can browse to, you should be able to load them up.
    Aug 2003
    Chicago
    Quote Originally Posted by Sonicxtacy02
    the way i was thinking is similar to this but only uses 2 buttons, up and down.
    the way it is in your screenshot are the playlist limited to how many buttons you have?
    Aug 2003
    Chicago
    should tell myself to RTFM, lol,
    didnt see the post right above mine,
  1. Relocating computer power button
    By King_Xerxes in forum General Hardware Discussion
    Last Post: 02-21-2007, 10:15 PM
  2. CF BETA 2 [1.3] Requests
    By camsgs3 in forum Centrafuse
    Last Post: 07-30-2005, 10:43 PM
  3. Remote Playlist Manager for Frodoplayer - 1.0 Beta 1
    By PatO in forum Software & Software Development
    Last Post: 03-17-2005, 02:58 AM
  4. button repeating bug?
    By scott_fx in forum Centrafuse
    Last Post: 02-24-2005, 12:35 AM
  5. RR fails to load / vis display glitch
    By RhinoT16S in forum RR Bug Tracker
    Last Post: 02-23-2005, 09:14 PM
