Results 11 to 20 of 23
Thread: Directions Indicator
  1. #11
    Variable Bitrate 307SW_NLD's Avatar
    Apr 2005
    The Netherlands
    Ok guys, here you go!
    These are the skin I made. I have the arrows also available in white (100x100). Distance to indicators still don't work due to a bug in MM. Hope to have FD working with it soon.
    My car: 2009 MAZDA CX-9 3.7L V6 runnin on LPG (Liquid Petrol Gas)
    Hardware: None at the moment
    Software: None at the moment
    See: Velleman K8055 Plugin for Road Runner
    Progress: [XXXXXXXXXX] 0 % DONE
  2. #12
    Raw Wave
    Jun 2004
    On the beach
    The codebase isn't there in RR currently to allow the turn arrows on skins, once it is then the skins are easy to do, the stuf MC_Stoo did was flash based and I'm trying to avoid using flash as much as possible due to speed issues.
  3. #13
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    the codebase is in there for MM, just not for FD, right? but guino should get it pretty quickly... also CDR had some flash ones that he could maybe release....
    Roy
    2005 Range Rover 4.4
  4. #14
    Apr 2005
    The Netherlands
    The codebase in indeed in for MM. I´m using the latest release myself. For FD some modifications will have to be made but it should be pretty easy.
  5. #15
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I've already added support for FD DIRECTION indicators... using the same MM images by 307sw_nld... will be out on the next release.
    Ride Runner RR's Myspace
  6. #16
    São Paulo, Brazil
    Has anyone implemented this?
    What skins/thread has the arrow images for me to download?
    Roy
  7. #17
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    This should work, but I can't test it yet.
    It should change the overspeed indicator in the bottom left hand corner to the direction indicators.
    If you have the brushed metal skin BMV2...
    Try this.
    Make a backup copy of DESTINATOR_GPS.skin
    Open the original and change to "OVERSPEED:B" to "DIRECTION"
    If it doesn't work, just change it back.
  8. #18
    São Paulo, Brazil
    but you need the arrow images dont you? from what I remember there are separate RIGHT, LEFT, STRAIGHT, etc images....
    that must be put in the current skin directory.... I want to put it on another skin thats why....
    Roy
  9. #19
    Jul 2005
    Hampshire UK
    The images are already in the BMV2 skin folder. They are all named MM_xxx where xxx is the direction like right turn, roundabout (circle?) etc.
    Sorry I can't test it but my Car PC is back at home several thousand miles away.
  10. #20
    São Paulo, Brazil
    I dont have it in my bmv2.zip! when was it added? isnt it available apart from the skin?!?! My connection is fing slow tonight cause I'm download a bunch of ****e...
    Roy
  1. How to set Freedrive directions volume
    By Phythorian in forum Road Runner
    Last Post: 07-28-2005, 05:35 AM
  2. Destinator gives the WORST directions
    By aoLhaTer in forum GPS
    Last Post: 03-22-2005, 03:44 AM
  3. Roundabout/Bad Directions
    By nibix in forum Map Monkey
    Last Post: 02-21-2005, 06:22 PM
  4. Replies: 2
    Last Post: 03-24-2004, 04:54 AM
  5. Looking for software that gives driving directions
    By jmhenry5150 in forum Software & Software Development
    Last Post: 05-28-2002, 09:23 PM
