Results 1 to 10 of 12
Thread: buttons ontop of indicators??
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Hopefully somebody can help me out with this one.
    I have a button that has an indicator inside of it (think box with smaller box inside). When i click the button it works, but the indicator dosent seem to work right, it just flashes once and button and indicator goes back to the off state, even though the indicator should be on.
    Now this works fine in the BAV2 skin, its being used on the mute button. If you click it you'll see a red dot start to blink on and off constantly. Not sure how the blinking is being done either.
    any ideas?
    May 2005
    Vienna, VA
    It should work fine. Try switching the order of the button and the indicator.
    As for the blinking, just add ":b" to your Indicator code. So for "MASTERMUTE", it would be "MASTERMUTE:b".
    Aug 2003
    Chicago
    ive tried switching the order but that dosent seem to help any. im about to try it with the blink hopeing that will force it to pop up.
    thanks
    Aug 2003
    Chicago
    well the blinking works, it just kind of blinks too fast for my taste, and for the indicator that its on it seems like a bit much to have it blink as its not something that needs attention like that. Is there a way to control how fast it blinks?
    May 2005
    Vienna, VA
    Unfortunately, I don't think there is.
    Actually, I remember having a similar problem. I was trying for a non-blinking indicator, too but couldn't get it to show consistently so I ended up having to make it blink. Maybe this is a bug in RR.
    FLAC J187's Avatar
    Nov 2004
    Boston
    Quote Originally Posted by b8bboi
    Couldn't you accomplish this by simply adding a label to your skin. ANd making the indicator solid red in the _ON skin .Jpg of whatever skin you are using?
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The problem is the the indicators are graphics like the buttons and when the button is drawn the indicator will be erased (if over the button).. blinking forces RR to redraw the indicator... But this is a good example of how you can use the image transparency.. if you make the area of the indicator PINK (on the ON/OFF/DOWN images), then RR will not mess with that area when drawing the button and the indicator should stay whatever it is. You may need an empty image to draw the first state of the button..
    Ride Runner RR's Myspace
    Variable Bitrate Viscouse's Avatar
    Jul 2005
    Motor City
    guino, this would be great to add to the
    Skin Commands.txt
    document, no?
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    Beginner skinner trying to understand Guino's explanation - so if I want the indicator on a button to maintain it's state without having the button redrawing wipe out the indicator, I draw a "pink" area on the button that I want the indicator to go, in the image file? Literally make the area pink? Any specific shade? Sorry if this is remedial.
    tja
    tja is offline
    Aug 2005
    sydney, australia
    u actually want magenta,
    R: 255 (FF)
    G: 0 (00)
    B: 255 (FF)
    2005 Nissan Xtrail
    DFI 855GME-MGF - Celeron M 1.4GHz - 256Mb RAM - 200Gb SATA HDD - OPUS 150w - Xenarc 700TSV
    worklog
  1. How-To: Relocating Screen Buttons
    By Altimat in forum Fabrication
    Last Post: 11-07-2007, 04:48 PM
  2. Labelling buttons for an OEM look - how?
    By Gibson99 in forum Fabrication
    Last Post: 02-17-2006, 08:20 PM
  3. Replies: 7
    Last Post: 02-05-2005, 07:41 AM
  4. Where to get black Lilliput buttons
    By Quattro in forum LCD/Display
    Last Post: 09-14-2004, 08:49 PM
  5. Where To Buy Buttons, Switches, Lights?
    By eCarô in forum General Hardware Discussion
    Last Post: 02-22-2004, 03:25 PM
