Results 1 to 10 of 10
Thread: My screen will be a little unique...
    Aug 2005
    Ohio
    At least I hope. I wanna know if any skins will support (or even RoadRunner for that matter) a 600x800 screen resolution?
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    just make your own, or RR will resize any of the existing ones
    Roy
    2005 Range Rover 4.4
    Aug 2005
    Ohio
    So RR is capable of running at 600x800 then? SWEET. Thanks
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    you mean 800x600 right???
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Aug 2005
    Ohio
    No sir, I mean 600x800. It's a 10" LCD Touchscreen I want to mount in my center dash tilted 90 degrees so it is a vertical display. It will be fricken huge lol, but it's going in a SUV so it should look juuuuust about right.
    This is why I was asking about software controlling the display to tilt it in another forum. Good for catching that though.
    Nov 2004
    10-4.
    Nissan Aux-in MOD
    Aug 2005
    Ohio
    It will still work?
    São Paulo, Brazil
    yes, if your video card can do it then your fine....any frontend can do that... youll ave to make your own skin though cause normal skins are made for 4:3, and your display will be 3:4 so it will look crappy unless u make ur own skin
    Roy
    Nov 2004
    I think you are wrong in you concept about skins.
    Show me a link to you screen.
    Nissan Aux-in MOD
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    use an application called " Pivot " to turn the rest of the OS screen. It works great. It's part of the TS for the lilliput, but should work an any monitor.
    This way, if your video card wont put out 600x800, just run 800x600 with pivot.
    Don
    EDIT: I once did this and frodoplayer ran fullscreen (proportional) side to side, and left room on the desktop. So you may not need to change a skin, unless you want it to cover the entire screen without stretching/shrinking images.
  1. Replies: 37
    Last Post: 03-19-2010, 01:08 PM
  2. Replies: 4
    Last Post: 01-29-2005, 06:35 PM
  3. Replies: 5
    Last Post: 04-30-2004, 11:25 AM
  4. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 02:16 AM
