Results 1 to 8 of 8
Thread: Error 13: Type mismatch
    Variable Bitrate Viscouse's Avatar
    Jul 2005
    Motor City
    Hey guys. I am getting this error with my new skin, and cannot figuire out why.
    I have the latest binaries of both RR & RRSkinEditor.
    Searches reveal this question was asked once before with no answer.
    I'm making a new skin. If I start with BAV2 and then switch to my skin, no problems. If I close RR, then reopen it with my skin, I get the error.
    Any clues?
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Post your menu.skin file... likely you have an invalid value or wrong definition on the file.
    Ride Runner RR's Myspace
    Jul 2005
    Motor City
    Thanks Guino! Your front end rocks, and I'm having a ball playing with it!
    It's very simple to start...
    Code:
    MEDIACAR Skin
    MEDIACAR menu Skin
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B11,629,521,60,70,"EXIT","Exit"
    B08,369,521,60,70,"EXIT","Exit"
    B14,729,181,60,70,"PHOCO",""
    B15,729,96,60,70,"EJECT",""
    B13,729,266,60,70,"LAUNCH",""
    B12,729,356,60,70,"EJECT",""
    B10,542,521,60,70,"MINIMIZE",""
    B09,459,521,60,70,"QUIT",""
    B07,199,521,60,70,"GAMMA",""
    B06,114,521,60,70,"MUTE",""
    B05,14,436,60,70,"EJECT",""
    B02,14,179,60,70,"GPS",""
    B04,14,355,60,70,"VIDEO",""
    B03,14,265,60,70,"AUDIO",""
    B01,14,95,60,70,"XM",""
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L01,9,16,73,25,055,055,055,12,"LCD Display Grid","TIME","Time"
    L02,9,40,73,25,055,055,055,16,"Arial Narrow:B","DATE","Date"
    /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name
    S,285,200,400,200,0,255,0,0,84,227,255,0,0,255,255,0,,14,"Arial"
    /, F, x, y, w, h, Movie name
    F,136,100,105,129,"XMlogo.swf"
    L,285,135,400,40,,,,,,"TAGARTIST",
    L,285,95,400,40,,,,,,"TRACKNAME",
    END
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    Viscouse,
    Your "TAGARTIST" and "TRACKNAME" labels at the bottom need to have a color and font defined or they need to be moved under the other labels like so:
    guino's Avatar
    Nov 2004
    Toronto, Canada
    It is a very bad practice to ommit information from object definitions..
    Those three lines are most likely your problem:
    S,285,200,400,200,0,255,0,0,84,227,255,0,0,255,255 ,0,,14,"Arial"
    The S definition you should have either TRUE or FALSE before the font size (or you may run into trouble).
    The L definitions should have the propper font color, size and name setup (or you may run into trouble). If you wish to hide the label, simply set W and H to 0 (ZERO), but all fields must be propperly filled up or I have no way to predict the results. It is also a bad practice to leave the ToolTip blank (you should set it to at least "").
    Jul 2005
    Motor City
    Duly noted.
    I shall clean up & see if the error disappears.
    Thanks for the input guys. I do appreciate it. Especially before I finish coding all the pages!
    Jul 2005
    Motor City
    Thanks guys, that did the trick.
    I don't know which in general, I just supposed I need to be a little cleaner.
    FLAC J187's Avatar
    Nov 2004
    Boston
    Yeah, your problem is most definitley within the 4 straight empty ,,.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
  1. Replies: 1
    Last Post: 06-10-2005, 03:09 AM
  2. Which type DC-AC inverter
    By smee in forum Power Supplies
    Last Post: 06-07-2005, 05:01 PM
  3. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 12:25 AM
  4. Problem with connecting 2 Type II pcmcia cards to a Type III slot.
    By AVmobile in forum General Hardware Discussion
    Last Post: 01-28-2004, 09:14 PM
  5. What type of Keypad should I use???
    By prerunnerv6 in forum General Hardware Discussion
    Last Post: 08-27-2002, 07:47 AM
