Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: start audio_player + visu at runtime?
    Newbie Nitrov8's Avatar
    Aug 2003
    Australia
    Iam making a skin specially for remote control use so will not be needing a whole lot of buttons in the skin itself and the less buttons I have to tab to the better
    I have it starting up straight to the audio player at the moment can I start the visu automacally at the same time? also anyway to prevent the menu screen flashing up before the audio player loads?
    here is a pic of my skin so far anyway:
    Raw Wave
    Jun 2004
    On the beach
    Love the cartoony sort of look Good to see someone doing a different style of skin
    May 2005
    Germany
    Hello,
    good job, can you tell me what´s the name of the visu in the bottom of your skin? Where can I download this visu?
    Ti-ejtsch
    Aug 2003
    Australia
    cheers guys
    I'm using a 5" PSone screen so only needed something simple and easy to read, any text smaller than 14 point is pretty much unreadable.
    The visu I'm using is Sexy Attached Analyzers v1.61
    FLAC J187's Avatar
    Nov 2004
    Boston
    HI, nice skin so far. To make RR load to the audio_player with Visualization running, enter RRconfig and add this to the box that says start command to execute - AUDIO||VISU
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    if you want to get rid of any flashing you might need to copy your audio_player.skin into menu.skin, and making a menu skin called something like menu2.skin...
    that way when it loads up menu.skin it is actually loading up the music plaer... I'm pretty sure it will work although it might not like some stuff (like visu) being as it thinks its in the menu... not sure, ull have to try
    Roy
    2005 Range Rover 4.4
    May 2005
    Germany
    @Nitrov8
    What settings must be where (Roadrunner/Winamp/visu) made to show the visu like yours (position/place in the skin).
    Ti-ejtsch
    Aug 2003
    Australia
    Quote Originally Posted by Ti-ejtsch
    @Nitrov8
    Ti-ejtsch
    In RRconfig check "other (window title)" and enter !attachanalyser
    Winamp/visu : unzip the attached vis_satan.rar into your winamp/plugins folder over the top of the others to get exactly size/look i have in mine, edit the .ini file x / y - hieght/width to suit.
    Enjoy
    Attached Files Attached Files
    Aug 2003
    Australia
    Quote Originally Posted by J187
    That works great but I now have a focus problem with the vis and I thought I had solved the focus prob ggrrr.
    Quote Originally Posted by RoyN
    I will give that a try in the next few days... cheers
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Okay, Now I want to see that PSOne friendly RR's skin.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. xbox + inverter + remote start + relay switch
    By ozstriker78 in forum Power Supplies
    Last Post: 08-24-2008, 09:44 PM
  2. Car won't start after carputer install
    By UnsanePyro in forum General MP3Car Discussion
    Last Post: 07-24-2005, 04:44 PM
  3. Carnetix Pulse Start to Alarm.
    By bluehcc in forum Power Supplies
    Last Post: 05-18-2005, 01:59 PM
  4. PW-120-M start question
    By JosepZ in forum Power Supplies
    Last Post: 02-06-2005, 05:46 PM
  5. Replies: 3
    Last Post: 05-04-2004, 04:24 PM
