Make one as the example without the satellite symbol... I like it...
I can easily create a "GPSSIGNAL" slider code that would allow for gif files to be drawn much like the phone's signal strenght is displayed right now. Let me know if there's an interest for that..
Ride Runner RR's Myspace
See my car and donate for spinning logos at www.ildena.it/carpc
Hello,
I tested it with swisch, but sometimes I canīt follow your tutorial. Swish show me follow:
ERROR: Cannot find variable or function 'GPSSAT' in statement:
Scene_1.Signal_BARS:nEnterFrame(includingFirstFrame)::if (_root.GPSSAT == "1")
Referenced from: "_root.Signal_BARS"
Could you help?
Don't worry about that... Swish will through errors because It can't find the GPSSAT variable. To test it, try exporting to swf first or doing a "Ctrl, T". To really test it, I'm afraid your going to have to skin it and hop in the car... or you can do it from home if your close to a window
Hi,
the problem is my .swf donīt work in my skin. I made the same like you in the tutorial. MM shows me 7 sats but my swf 0. I donīt know whatīs wrong?
Ti-
Here my skin file
MEDIACAR Skin
MEDIACAR MM Skin
/, B, x, y, w, h, Command;COMMANDCODES, Tooltip
B01,680,4,55,55,"CLOSE","Close"
B02,740,4,55,55,"EXIT","Exit"
B03,191,3,55,55,"PREV",""
B04,690,547,90,50,"STOP",""
B05,565,547,91,50,"PLAY",""
B06,554,3,55,55,"NEXT",""
B12,3,3,55,55,"VOL-","Volume-"
B11,63,3,55,55,"VOL+","Volume+"
/, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
//S01,86,544,438,30,086,544,438,30,H,01,"POINTER2.gi f",12,"SONGPOS",""
/, Y, Back Slider file path
Y01,"zslider1\slider_*.gif"
S01,265,9,215,6,314,445,215,16,H,01,"zslider1\poin ter.gif",013,"MASTER",
/, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
L01,10,548,100,25,255,255,255,15,"Arial Narrow:B","TIME","Time"
L02,10,573,100,25,255,255,255,15,"Arial Narrow:B","DATE","Date"
L03,265,20,270,30,255,255,255,16,"Tahoma:B","TRACK NAME","scroll"
L04,235,570,150,020,128,255,128,15,"Arial Narrow:B","MM;STREET",""
L05,395,570,180,20,128,255,128,15,"Arial Narrow:B","MM;CITY",""
L07,195,550,060,020,128,255,128,15,"Arial Narrow:B","MM;ETA",""
L08,325,550,260,20,128,255,128,15,"Arial Narrow:B","MM;ETR",""
L09,140,570,85,20,255,255,255,15,"Arial Narrow:B","=Standort:",""
L10,140,550,45,20,255,255,255,15,"Arial Narrow:B","=ETA:",""
L11,275,550,040,020,255,255,255,15,"Arial Narrow:B","=ETR:",""
//L12,142,5,35,25,255,255,255,15,"Arial Narrow:B","=Car:",""
//L13,142,30,35,25,255,255,255,15,"Arial Narrow:B","=Out:",""
//L14,180,5,45,25,128,255,128,15,"Arial Narrow:B","TEMP1",""
//L15,180,30,45,25,128,255,128,15,"Arial Narrow:B","TEMP2",""
L16,142,5,35,25,255,255,255,15,"Centaur:B","MM;SAT ELLITECOUNT",""
/, F, x, y, w, h, Movie name
F01,5,550,350,50,"GPSSAT.swf"
/, A, x, y, w, h, color;RGB
A01,0,59,800,483,000,000,000
/, I, x, y, w, h, Code;INDICATORCODES
I01,125,001,070,550,"OVERSPEED:B"
END
Like i said in post#18, you need the GPSSAT label in there or it's not going to work. Add this and let me know what happens:
L,0,0,0,0,,,,,,"GPSSAT",
Hi,
Itīs working now, great. Sorry that I didnīt understand what you ment with the gps-label. Thanks a lot!!! Hope you are not too angry with me!
See you
Ti-ejtsch
One triesOriginally Posted by DiNASTY
