Results 1 to 3 of 3
Thread: sending mbm5 temps to flash?
    Newbie Nitrov8's Avatar
    Aug 2003
    Australia
    Ok it seems flash doesn't pick up temp readings from mbm5 labels, any way to do this?
    I have CPU and MEM in flash no worries using _root.CPU and _root.MEM variables but when trying _root.mbm02 ect. no go, I do have the labels in the skin because I run them visible when testing
    can it be done?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    First, I don't know if Flash is case sensitive, so I'd try _root.MBM02 first. Then Make sure you have a label defined for "MBM02" on the same .skin file and then verify MBM is running. The easiest thing is to make a label on the .skin and placeit on a visible location for testing so you "see" it works, then check it in Flash. There's no reason why it shouldn't work because all data is channeled through the same code.
    Ride Runner RR's Myspace
    Aug 2003
    Australia
    Damn i feel silly
    I did have the variable in flash as _root.MbM02 with a lowercase b , thats how I also have the label in my skin file with a lowercase b.
    So it seems the label in RR isn't case sensitive but flash is. Thats what threw me
    All working now.
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 08:23 PM
  2. Replies: 1
    Last Post: 09-14-2005, 11:37 PM
  3. Samsung 16GB flash drive
    By hanzacra in forum General Hardware Discussion
    Last Post: 05-25-2005, 04:24 PM
  4. 800mb Flash Drive as bootable drive
    By Tidder in forum General Hardware Discussion
    Last Post: 04-27-2005, 06:40 PM
  5. Can Flash resize?
    By froop in forum Road Runner
    Last Post: 04-16-2005, 11:58 AM
