Results 1 to 10 of 12
Thread: blink indicator speed?
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Hey guino:
    not a huge issue, but is is possible to have some options as to how fast the blink indicators blink? Like a slow, medium, fast, where the current speed would be considered fast, when windows task bar flashes would be considered medium and slow would be half of that.
    I would like to use blinking idicators more but the current speed it blinks at is really fast. Heck you can do way with the slow, medium, fast stuff and just make the setting in miliseconds "ONLINE:b,200".
    Again, not a huge issue, just something to think about for future updates.
    thanks
    Jan 2007
    Greece
    Hi, i'm looking for the same.
    Any news on these?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The blinking speed is set to 200ms ON, 200ms OFF - it's hard coded. I don't really know how much work that involves, but there would be a minimum allowed time for sure.
    Ride Runner RR's Myspace
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by guino
    ....Was hard coded
    K, feature done, will be in next release...
    C posting below for newer update
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Jan 2007
    Greece
    Yeaaaaa!!
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    K, for the mr winee above.... we now have...
    To spec a custom blink rate of a indicator with same on/off times add a 6th parameter to your indicator definition line...
    I, 20,30,40,40,"Mute:b",300 ( in 100th's of a sec )
    This would be on for 300ms and off for 300ms.
    To spec a custom blink rate of a indicator with a different on & off times add a 6th & 7th parameter to your indicator definition line...
    I, 20,30,40,40,"Mute:b",300,500 ( in 100th's of a sec )
    This would be on for 300ms and off for 500ms.
    Any rates not specified or < 200, will default to current blink rate..ie 200ms
    My test subject was using 4 mute ind's. So i had four independently blinking inds blinking at their specified rate.
    On top of that....there is also a cmd that can change them at run time using same layout as skin definition
    Syntax: "SetIndBlRate;<indicator code>[;<On Time>;<Off Time>]"
    Example 1: "SetIndBlRate;mute;350"
    Sets the mute to bllink 350ms on & 350ms off
    Example 2: "SetIndBlRate;mute;350;750"
    Sets the mute to bllink 350ms on & 750ms off
    Example 3: "SetIndBlRate;mute"
    Sets the mute to blink back to the default of 200ms on & 200ms off
    Now that should be worth something...Click here->
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Begging for reps?
    How low can you go?
    Next you'd be asking to be a member of remember rule no. 1 - edited by council member
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Well, I did put in the extra time/effort for your requested additional functionality....
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I just asked that before others did, you know they would have.
    In fact I probably saved you time reopening the code by asking for it now
  1. I have the most powerful speech control interface.
    By kykeon in forum Software & Software Development
    Last Post: 12-12-2006, 09:55 PM
  2. 150w opus, both leds blink once, then 20second pause
    By diablo266 in forum Power Supplies
    Last Post: 03-21-2005, 06:58 PM
  3. 3 Blink blinkers? How to?
    By judoGTI in forum General Hardware Discussion
    Last Post: 08-26-2004, 01:09 PM
