do you have all of the lines in FD's sdk.ini set as RoadRunner?
Hi.
I have FreeDrive working perfectly in RoadRunner.
I have designed a skin for FD. and have the following code in it:
How can I get the direction symbols to be displayed in the skin.
I have the MM direction symbols in my skin but they are not displayed.
Am I doing something wrong or is this a bug ?
MEDIACAR Skin
MEDIACAR F-CNS(800x600Stretched)"ExternalGPS" Skin
external_gps_empty.jpg,external_gps_off.jpg,extern al_gps_on.jpg,external_gps_down.jpg
/, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
L1,21,9,50,22,0,255,0,15,"MgDigital","=ETR","cente r"
L2,2,31,83,33,255,255,255,18,"MgDigital","CUSTOMFD ETR","center"
L3,21,73,50,24,0,255,0,15,"MgDigital","=ETA","cent er"
L4,2,97,83,33,255,255,255,18,"MgDigital","CUSTOMFD ETA","center"
L5,13,141,66,24,0,255,0,15,"MgDigital","=SATS","ce nter"
L6,2,165,83,33,255,255,255,18,"MgDigital","CUSTOMF DSATS","center"
L7,22,209,47,24,0,255,0,15,"MgDigital","=DIST","ce nter"
L8,2,233,83,33,255,255,255,16,"MgDigital","CUSTOMF DDIST","center"
L9,2,351,83,33,255,255,255,16,"MgDigital","CUSTOMF DNEXTMANDIST","center"
L10,13,415,66,24,0,255,0,15,"MgDigital","=HEAD","c enter"
L11,2,439,83,33,255,255,255,18,"MgDigital","CUSTOM FDHEAD","center"
/, I, x, y, w, h, Code;INDICATORCODES
I01,7,280,73,71,"DIRECTION"
/, B, x, y, w, h, Command;COMMANDCODES, Tooltip
B01,751,3,86,74,"SENDMSG;FreeDrive;ZOOM:-50",""
B02,751,80,86,76,"SENDMSG;FreeDrive;ZOOM:+50",""
B03,751,160,85,77,"MENU;FDMENU.SKIN","exit"
B04,751,241,86,75,"SENDMSG;FreeDrive;GPSconnect",
B05,751,321,86,75,"NEXT","Next/FF"
B06,750,399,88,76,"EXIT","exit"
/, A, x, y, w, h, color;RGB
A01,92,3,653,475,000
END
The road is long but we are getting there.
Roy
2005 Range Rover 4.4
Originally Posted by RoyN
No, only the ones I use. Do I have to activate all of them ?
One or more of them (I dont remember which one) are required to get info to the indicator.... are you sure that one is on? if not, put them all as RoadRunner for testing, you can then remove the useless ones if you find out that this works....
Roy
OK I'll try it out
I think RR needs the NEXTMAN or something like that.. then if you have the MM_* images on the skin folder it should work. But this is something you'll only see working DRIVING or simulating GPS movement for routing.
Ride Runner RR's Myspace
