Page 15 of 44 FirstFirst ... 5678910111213141516171819202122232425 ... LastLast
Results 141 to 150 of 437
Thread: Release: Proximo's CF style skins
  1. #141
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    Quote Originally Posted by b8bboi
    Hark, I haven't tested the XM skin since I don't have the hardware. You can use SkinEditor to rearrange the components and maybe post back the fix here and I'll update it. Thanks.
    I'll try - I'm very new at this, but maybe this is the push I need to learn more about it. Great work on the skin.
  2. #142
    Feb 2005
    Atlanta, GA USA
    Quote Originally Posted by guino
    This is a known issue if you have a XMPCR instead of the XMD1000 ... sometimes also if you have a crappy/cheap USB->Serial Adapter for the XMD.
    I have the XMD unit (the one that's free after rebate now!). I had WebDog make me a cable, it seems very high quality and works very well - not sure if this is to blame for my problem. I'll also search if there's a way to make RR "reload" the XM screen on standby resume, which I think would solve it.
  3. #143
    Aug 1999
    Birmingham, Alabama (War Eagle!)
    This is definitely a solid skin/foundation to build on Hark for your learning.
  4. #144
    Jun 2002
    Virginia
    Ha, I'm learning too. I didn't know anything about skinning until about 30 minutes ago. The Skineditor is crucial. Makes things understandable. Anyway, I have attached a modified XM skin that properly lines up the signal bars on my desktop running RR at 800x600. Now we'll see if it also works on my carputer. Let me know if it works for you.
    Oops, when I tried on carputer the indicators were perfect, but everything else was messed up. I don't advise using the file. I'll work on it some more.
    Attached Files Attached Files
  5. #145
    Falls Church, VA
    OK, why does my igmod still have the title bar at the top? Its in the right place, but as soon as i press the volume button it falls to the back of the screen. There is something I am not doing right... anyone?
    I have RR config set as external, with it pointing to igmod. I have the window name as --iGmod something--. I tried that and iGuidance with no change.
  6. #146
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    --iGmod Reloaded--
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
  7. #147
    Falls Church, VA
    Quote Originally Posted by PURDooM
    --iGmod Reloaded--
    correct. That should embed the window into RR right? eliminating the title bar and allowing normal button fucntionality without sending the application to the rear?
    edit - got it... typo
  8. #148
    Falls Church, VA
    Has anyone gotten the CDrip application to work? I cant seem to get it to close.
  9. #149
    Jun 2002
    Virginia
    XM Signal Level Indicator Update:
    The XM skin contained in the above XM.zip file does fix the locations of the XM signal strength indicators when viewing RR at 800x600 and 800x480. The XM problem I mentioned was not related to the edited skin, but to the fact that XM had inadvertantly cancelled my account. All's working fine now.
  10. #150
    May 2005
    Vienna, VA
    Added 800x600 version for CFX Blue. See first post for link.
  1. mac style skin release...
    By btbe in forum RR Skins
    Last Post: 08-14-2007, 10:07 AM
  2. Cf - Corvette Zo6 Style...
    By BLOWNZO6_pc in forum RR Skins
    Last Post: 01-15-2006, 09:13 PM
  3. Why we need PSD files from CF std skins
    By justintime in forum CF Plugins
    Last Post: 11-05-2005, 08:20 PM
  4. XP Pro on CF card working!!
    By knubile in forum WinNT Based
    Last Post: 01-03-2005, 07:48 PM
  5. XP on CF II Drive
    By NOS TANG in forum Software & Software Development
    Last Post: 11-30-2004, 02:20 PM
