Page 21 of 44 FirstFirst ... 111213141516171819202122232425262728293031 ... LastLast
Results 201 to 210 of 437
Thread: Release: Proximo's CF style skins
  1. #201
    Maximum Bitrate LiquidKernel's Avatar
    Feb 2005
    Oh wow this skin is GORGEOUS! I'm giving this one a try! Kudos for the hard work.
  2. #202
    Newbie strabo's Avatar
    Jun 2005
    Baltimore
    Man this skin is awesome but I want Iguidance embedded like I see in other posts. I can't get the dvd app to launch with this skin any ideas? I am using windvd 4.
  3. #203
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Quote Originally Posted by strabo
    I know purdoom is working on verison of igmod that will work with this skin. He has alson created a skin maker too. I am hopeing that he releases it within the next couple of weeks.
  4. #204
    May 2005
    Vienna, VA
    You have to set up iGuidance as your external GPS. Read the FAQ on how to. To get rid of the borders and the nag screen, you need to use either Skinbedder or iGSkinner or just wait for Purdoom's new version of iGMod.
    As for DVD, I didn't make a skin for WinDVD since I don't use it. You can make your own or borrow one from the Brush Metal skin.
  5. #205
    May 2005
    Vienna, VA
    Quote Originally Posted by Musashi450
    Anyone know if a new version is in the works? I'm really interested in the sync option. I think having the ability to change weather city through the skin and maybe showing dopler would be nice. Just a thought
    I'm not working on a new version as of now. The sync button is just there so you can add your own app. I personally use robocopy. Others may use other syncing apps. You can only change the weather city through RR.ini.
  6. #206
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by b8bboi
    Well you could update a bug... on the blue skin iGuidance embedding both of the zoom buttons have the same actions (zoom in i think)
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
  7. #207
    May 2005
    Vienna, VA
    Quote Originally Posted by PURDooM
    Thanks for pointing that out. I already fixed this bug but forgot to upload the files. All downloads in the first post should contain the latest bug fixes.
  8. #208
    Dec 2005
    I figured I will post a problem that I'm having here since I've only observed it with the cfx 800X600 skin. Everytime the program starts or another button is pressed, the volume down button appears like its being pressed (it turns green) however the volume isn't actually being turned down. The only time it ever appears to turn stop being highlighted green is when I actually tap the volume down button. It's not affecting anything, just extremely annoying. Thanks
  9. #209
    May 2005
    Vienna, VA
    Musashi, this is because any time a button is pressed, RR placed the mouse cursor on the bottom left of your screen, which causes the volume down button to be "on." I didn't know this when doing the skinning otherwise I would have moved it up by a line or so. Fixing this would require changing all references to that button in all .skin files. Personally it doesn't bother me much at all so I haven't done that. You can kind of "fix" this by setting the resolution to 800x599 in general.ini.
  10. #210
    Jun 2005
    Anoka County, MN
    b8bboi: When iGmod (I am assuming anything else as well?) is embedded in the gps window 9 times out of 10 when I press any command on the gps_external skin (including switch to music or pause music) RR ends up hiding the window and instead showing the main button skin, yet it still executes the command. Sometimes it works properly.
    Are you aware of the cause to this problem, and if so a solution? Or is this RR specific?
    I have not tried iGmod with any other RR skin, so I do not know if it is my fault.
  1. mac style skin release...
    By btbe in forum RR Skins
    Last Post: 08-14-2007, 10:07 AM
  2. Cf - Corvette Zo6 Style...
    By BLOWNZO6_pc in forum RR Skins
    Last Post: 01-15-2006, 09:13 PM
  3. Why we need PSD files from CF std skins
    By justintime in forum CF Plugins
    Last Post: 11-05-2005, 08:20 PM
  4. XP Pro on CF card working!!
    By knubile in forum WinNT Based
    Last Post: 01-03-2005, 07:48 PM
  5. XP on CF II Drive
    By NOS TANG in forum Software & Software Development
    Last Post: 11-30-2004, 02:20 PM
