Page 28 of 44 FirstFirst ... 181920212223242526272829303132333435363738 ... LastLast
Results 271 to 280 of 437
Thread: Release: Proximo's CF style skins
  1. #271
    May 2005
    Vienna, VA
    Here you go. Unzip confirm.zip into your CFX skin folder.
    As for DELETEFILE, like I said you can change line 71 in audio_player.skin where it says
    Code:
    B00,245,304,87,55,"MENU;sort_menu.skin",""
    to
    Code:
    B00,245,304,87,55,"DELETEFILE",""
    and make it your delete button.
    Attached Files Attached Files
  2. #272
    Constant Bitrate m-ruiter's Avatar
    Jul 2005
    Kortenhoef
    Just found a little buggy,
    Just a small one:
    Its in the radio skin and the frequency up is frequency down.
    so this is how the section needs to be:
    radio_player.skin
    /Media Buttons
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B00,224,519,88,82,"FREQ-","Previous"
    B00,313,519,91,82,"SCAN",""
    B00,405,519,88,82,"SURF",""
    B00,493,519,84,76,"FREQ+","Next"
    I attached the good file
  3. #273
    Falls Church, VA
    you rock you rock you rock you rock!!!!
  4. #274
    Falls Church, VA
    hmmm, ok, got it running, but after i hit OK, nothing happens. The confirm window closes but The song is still there. Am i missing something?
  5. #275
    May 2005
    Vienna, VA
    Will, I don't know. I suggest you try this feature with the default skin (BMV2) first and see if it works there.
  6. #276
    Falls Church, VA
    ok, thanks much!
  7. #277
    Variable Bitrate wfs1's Avatar
    Oct 2005
    Arkansas
    Thanks to b8bboi for Lots of work on this skin
    b8bboi,
    I wanted to personally thank you for your hard work. I've been too busy with Phoco to stop and reflect.
    Finally, got the OBD2 skin embedded and working, also the Phoco skin is settling down a bit.
    Here's a couple snaps.
    http://us.a2.yahoofs.com/users/43f52...Ay.PEBTNWjYzHv
    http://us.a2.yahoofs.com/users/43f52...Ay.PEB8JQd2rQg
  8. #278
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    broken links
  9. #279
    Falls Church, VA
    For some reason my "more" button on the main menu no longer works. I wish i could tell you when it stopped working (after using igmod, embedding an app or installing the custom delete function) but i havent used the button in a while.
    Any idea of what/where i can check to figure it out?
  10. #280
    May 2005
    Vienna, VA
    Your ExecTBL.ini file probably got modified. Put these 2 lines back in.
    Code:
    "MAIN_MORE","LOAD;menu2.skin"
    "MENU_MORE","LOAD;menu2.skin"
  1. mac style skin release...
    By btbe in forum RR Skins
    Last Post: 08-14-2007, 10:07 AM
  2. Cf - Corvette Zo6 Style...
    By BLOWNZO6_pc in forum RR Skins
    Last Post: 01-15-2006, 09:13 PM
  3. Why we need PSD files from CF std skins
    By justintime in forum CF Plugins
    Last Post: 11-05-2005, 08:20 PM
  4. XP Pro on CF card working!!
    By knubile in forum WinNT Based
    Last Post: 01-03-2005, 07:48 PM
  5. XP on CF II Drive
    By NOS TANG in forum Software & Software Development
    Last Post: 11-30-2004, 02:20 PM
