Originally Posted by BLOWNZO6_pc
I must be missing this step becaue I followed you instuctionsand nothing happened
1. You have to copy all of the info from the EXECtbl.ini file that came with the skin into the main one for Roadrunner.Originally Posted by aducrejr
2. You have to be sure your file is also pointing to the correct location for your iGuidance.
The file that came with the skin says -
"iGuidance_Fullscreen","LOAD;external_gps_full.ski n;RUN;C:\Program Files\Road Runner\SKINbedder_v2.99999\SKINbedder.exe;SKINbedd er"
BUT mine is at -
"iGuidance_Fullscreen","LOAD;external_gps_full.ski n;RUN;C:\Program Files\iNav\iGuidance\iGuidance.exe;!IntellinavWCls"
Be sure your window name is correct, etc. What you are doing is setting up this string so you don't have to type it in everytime.. whenever you have iGuidance_Fullscreen in the skin, it will point to this above.
Hope that helps.
Make sure you confirm your window setting with Winspector Spy.Originally Posted by aducrejr
It is CLS.. not CIS.. the L is little of course.
Double check that window setting.
Are all of the keys and the GPS working in the normal GPS window?
Originally Posted by chewEboy
PM me and I'll send you the Ford one.
everything is working fine. until I try full screen hopefully once I install the computer in the car this feature won't be a big dealOriginally Posted by BLOWNZO6_pc
The clocks are down, anybody know where I can get the VW ones?
Pretty please?Originally Posted by t_bear
So how is everyone removing unwanted tracks from their playlist? I'm going to replace the album button on the audio_player skin to a minus instead I guess. Or is there some obvious method already in the skin which I have overlooked?
In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
I re-installed everything and change that setting and now everything works fineOriginally Posted by BLOWNZO6_pc
Thanks Alot Blownz06_pc
Glad you got it worked out...Originally Posted by aducrejr
