Page 40 of 44 FirstFirst ... 303132333435363738394041424344 LastLast
Results 391 to 400 of 437
Thread: Release: Proximo's CF style skins
  1. #391
    Aug 2004
    Quote Originally Posted by kbreeden
    I've never seen that window name before. Unless something weird is going on I believe the window name should be "Iguidance." In fact, if you're using the CFX skin the best thing to do would be to go to the IGMon thread, download IGMon and follow the instructions.
    Well, I always did have the window name set as iGuidance. Reading through the thread about halfway somebody mentioned Winspector came up with !IntellinavWCls, so I switched it to try it out, obviousely it didn't work. Come to think of it, I think the buttons may have worked at some point. Is it "Iguidance" or "iGuidance"? Does it matter? IGmon was the big button mod right? Cuz I know I have that done already.
  2. #392
    Mar 2006
    Los Angeles, CA
    I'm having a bizarre problem with this skin's OSK and Firefox. Whenever I type anything, I get double characters (as in "ggooggllee" when I type "google"). Strangely this only happens when entering free text (like in a text box), but never if typing a URL using the URL button. Any ideas?
  3. #393
    May 2005
    Vienna, VA
    Nope, not a skin problem. It's a known issue with RR.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
  4. #394
    Constant Bitrate donde's Avatar
    May 2005
    Texas
    b8bboi,
    Would you be willing to make two 80 x 80 pixel bitmap images for iG3 that match your skin, one for the menu button and one for the mute/unmute button? We can keep the default images on the rest of the menus at least for now, since they are very usable, but these two always visible buttons are really an eye sore. Their crayola looks just don't go well with your sleeker skin. Reshacking our own matching buttons in would be much better. I tried my own hand at it, but couldn't get the buttons exactly the same. Thanks
  5. #395
    Mar 2006
    Los Angeles, CA
    Quote Originally Posted by b8bboi
    Ahh, thanks... haden't come across that one before! I'll start searching, but maybe someone can at least tell me if there's a known fix for it...?
    Edit: found the bug tracker thread for it, thanks!
  6. #396
    Aug 2006
    Hi guyz
    great skin!
    but i have some little problems configuring all correctly
    b8bboi how big is your rr folder?
    maybe you can zip it and send via mail ? or better only the configuration files needed ?
    thanks
  7. #397
    Variable Bitrate fonseca's Avatar
    Apr 2005
    Virginia
    There's not much room on the audio screen for a slider and I don't want to mess up the current layout.
    I ended up removing the "second set" of track information on the audio screen, and using that entire area for a long slider, which makes it easier to find a certain spot in long tracks. I really need to figure out how to make cuesheets for all my long MP3, AC3 and DTS files, which I don't want to split into individual tracks.
    I also replaced the album button with a remove track button. You can always switch to album mode when browsing in list mode anyway.
    This is the only skin I have used for months now. Still loving it.
    In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
  8. #398
    Jan 2006
    MN
    Anyone have a good "subaru" logo that i can use???
    Josh
    '04 WRX
  9. #399
    Jun 2005
    my iguidance doesn't fit the screen, can anyone explain how to fit it?
  10. #400
    Aug 2005
    Quote Originally Posted by QFCK2001 View Post
    For some reason your window is not the right side.
    You need to go into RREDITOR and correc it.. or find the txt file associated with your GPS skin and go into that and correct it in notepad.
    2002 Twin Turbo ZO6
    2005 Hummer H2
  1. mac style skin release...
    By btbe in forum RR Skins
    Last Post: 08-14-2007, 10:07 AM
  2. Cf - Corvette Zo6 Style...
    By BLOWNZO6_pc in forum RR Skins
    Last Post: 01-15-2006, 09:13 PM
  3. Why we need PSD files from CF std skins
    By justintime in forum CF Plugins
    Last Post: 11-05-2005, 08:20 PM
  4. XP Pro on CF card working!!
    By knubile in forum WinNT Based
    Last Post: 01-03-2005, 07:48 PM
  5. XP on CF II Drive
    By NOS TANG in forum Software & Software Development
    Last Post: 11-30-2004, 02:20 PM
