Page 6 of 44 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 437
Thread: Release: Proximo's CF style skins
  1. #51
    May 2005
    Vienna, VA
    Just to let you guys know, I'm working on the photoshop script for altering the colors right now. I'll be releasing the green and orange (and maybe red) versions soon.
  2. #52
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    Awesome
    Question about the PSD: Is there a way to save it so that all the proper files are output and you dont have to sit there forever turning off and on layers and saving each individual one?
    Also I was having trouble opening the PSD in CS2 but it opened fine in 7
  3. #53
    Aug 1999
    Birmingham, Alabama (War Eagle!)
    aolHater, i was considering checking out RR for a while until david gets all of the bugs, slodowns etc in CF fixed.
  4. #54
    Mar 2003
    Rohnert Park, CA
    CF is pretty good but the functionality of the program is really lacking
    The slow development is also not helping
    The only thing I dont like about RR is the interface but with this skin it would be near perfect. Best of both worlds
  5. #55
    Aug 1999
    aolhater, that's what i was thinking too, when i saw proximo's skin for CF, i was like, ok yeah this is what we need, and with it getting moved to RR, thats a huge plus.. RR has SO Much functionality, and like mentioned, development time is quick thanks to Guino. I'll most likely switch back and forth between the two, but I'll be playing with RR more right now.
    btw, i'm a nissan family member as well, and was thinking of buying some g35 18" wheels and rims.. you reocmmend any forums, or locations to go to purchase these wheels?
    thanks
  6. #56
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Quote Originally Posted by b8bboi
    You know what b8, thats probably the better way to go instead of trying to build it into RR. Just give out the .psd's and somewhere have a script where you can drop in the RGB color of your choice and they can run it, if they have photoshop of course....
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
  7. #57
    Mar 2003
    Rohnert Park, CA
    Quote Originally Posted by defsquad
    thanks
    Youre in great luck if you're looking for 18" stock wheels
    People over at g35driver.com are selling theirs all the time. Check it out
  8. #58
    Aug 1999
    b8bboi,
    I modified the ExecTBL.ini and put it in the root RoadRunner folder, however it is pointing to a skin file that did not exist in your zipped up skin package. I personally use iGuidance as well and was hoping to get your intended iGuidance settings. Am I missing something to get iGuidance with more iGuidance related buttons in full screen mode? Also, was I right to put the ExecTBL.ini into the root of the RR folder?
    Thanks for your help and for porting this skin.
  9. #59
    May 2005
    Vienna, VA
    The ExecTLB.ini file must be inside the CFX skin folder. Make sure you have the latest RR.
    You're right that there's a bug in my ExecTBL.ini file. Line 17 should read.
    /** Path to iGuidance
    "iGuidance_Fullscreen","LOAD;external_gps_full.ski n;RUN;C:\Program Files\Road Runner\SKINbedder_v2.99999\SKINbedder.exe;SKINbedd er"
    I had "external_gps_fs.skin" there before.
    I'll be posting a new version with some bug fixes soon.
  10. #60
    May 2005
    Vienna, VA
    Green, Orange and Red versions posted. See first post for download links.
    To make your own color, you need Adobe Photoshop.
    Download this action script and load it into you Photoshop action panel.
    http://download.andgear.com/rr/skins...bboi/Green.atn
    It's for green but change the Hue/Sat action to get different colors. Open an image (pick one from CFX). Go to the Action panel -> Record. Change the Hue/Saturation/Lightness until you're satisfied. Stop recording. Delete the old Hue/Saturation action. Move the newly recorded Hue/Saturation action to where it was.
    More Instructions:
    1. Create a new folder, call it CFX_Images. Copy all .jpg files from the original CFX folder into this one. (Note: DO NOT copy the GIF files).
    2. Create another folder and call it CFX_Mod. (Make sure it's empty before you continue)
    3. Open Photoshop -> File -> Automate -> Batch...
    4. Select the Green action above.
    5. Select CFX_Images for the Source folder.
    6. Select CFX_Mod for the Destination folder. Check "Override Action Save As Commands."
    7. Click OK and wait for Photoshop to complete the task.
    8. Make a copy of the CFX folder and call it, say, CFX_Purple.
    9. Copy all images from CFX_Mod into CFX_Purple, overwriting the existing ones.
    10. (Optional) Open all the .skin files in your text editor and change the following color values to match with your new skin. I recommend Text Pad. Best text editor I've used.
    List Selected Item Background: 105,152,186 -> something else
    List Selected Item Foreground: 19,46,76 -> something else
    LCD background in OSK, Num_OSK and Phoco: 42,98,147 -> something else
  1. mac style skin release...
    By btbe in forum RR Skins
    Last Post: 08-14-2007, 10:07 AM
  2. Cf - Corvette Zo6 Style...
    By BLOWNZO6_pc in forum RR Skins
    Last Post: 01-15-2006, 09:13 PM
  3. Why we need PSD files from CF std skins
    By justintime in forum CF Plugins
    Last Post: 11-05-2005, 08:20 PM
  4. XP Pro on CF card working!!
    By knubile in forum WinNT Based
    Last Post: 01-03-2005, 07:48 PM
  5. XP on CF II Drive
    By NOS TANG in forum Software & Software Development
    Last Post: 11-30-2004, 02:20 PM
