I didn't read the suggestions in the MC1.0 thread, but you cold try and convert the jpg's to "baseline standard jpgs" as I believe Flash has trouble reading those progressive jpgs.
I've done all the research, but still haven't found the solution to my problem... I have a *.jpg as album art in one of my folders. I named it album.jpg , and I copied it and named the copy folder.jpg (and Folder.jpg). I have the .jpg set in RR setup for album art. The file displays correctly in the Load window, but it doesn't show up as the background of the Menu screen, nor does it show up in the My Audio screen. In other words, it shows up on the LOAD screen (after hitting View to get it to show icons), but doesn't show up anywhere else. I have the latest RR version (10-31-05), and I have the latest Flashplayer installed (8.0.22.0). I made the folder.jpg visible (deleted the hidden/system one). I did all the suggestions in the MC1.0 thread for this problem, but nothing works still. The "time elapsed", track number, and total time things show up correctly on the Menu screen too, I just can't get album art to work! Any help?!
I spent a lot of time sorting out this issue for myself. It sounds like it should work.Originally Posted by WxGuy1
If you're still having problems .zip a copy of the music file with the folder.jpg in it and email it to me and I can see if it works or if I can see the problem.
OK, I made sure the Folder.jpg (and album.jpg to experiment) files were standard jpg encoded. Do they need to be a certain size? I've tried like 300x200, 300x300, 200x200, and a few other combos... Again, the album art shows up when I try to load the music:
After I load the folder, however, there's no hint of the album art:
post the jpg, maybe someone can debug it.,...
i suggest you try it on a different path (maybe for some reason you are running a long path which causes probs? not sure though....how is your current path?
Roy
2005 Range Rover 4.4
Thanks for the help guys... The Path to that particular folder is C:\MP3s\Garth Brooks\Seven\ (the directory in which the songs in that album are located)... Here is the jpg (at http://www.tornadocentral.com/now/folder.jpg )
amazing skin, i must say! i will now be switching to road runner because of itone question, how can i make the font smaller on the music screen so i can see more songs listed? thanks
update your flash to flash 8 player, thats your problem !, either that or your not running the latest RR.. you can see if your running the latest RR buy opening up the main.skin and editing say the time to albumart, you should then see the path to your albumart if a picture is there.. if no path is shown then you know its your RR that needs updating. These are the only two things that could be wrongOriginally Posted by WxGuy1
CdR
Is this a real pic or a photoshopped one?
That's what I supposed to get from "Visual" buttom. I've downloaded Winamp 2.95 so I can see vis window on mp3 loading window. I'm afraid that Winamp vis window can't be embedded, can it?
Sorry my poor English! I've learned more English from Internet that from school.
Of course it's embedded...
Old setupEpia M10k, Cubid 2699R case, 512MB, 40GB 3.5" driveNew setup
Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
