check out get rid of the winamp border showing VisOriginally Posted by damoru
This is great stuff!
Is there anyway to make that spedometer actually work like the real thing?![]()
If your running FreeDrive and you have installed the stuff that came with the skin then if you are getting a gps signal the speedo will work :-) I have yet to ammend it for kmOriginally Posted by Cris
CdR
Current Flash Version: 8.0.22.0 (from http://www.macromedia.com/cfusion/kn...fm?id=tn_15507 )Originally Posted by CdRsKuLL
Current RR version: 10-31-05.
I'm going to reinstall RR and see what happens. This can't be an issue of whether I have the wrong version of Flash player or RR, since both pieces of software are the most recent version.
Well, I should have just lived without Album Art... I uninstalled RoadRunner, deleted the directory, then reinstalled RoadRunner and the MC2.0 skin. Still no album art, and now the text of all music files and folders in the Audio_browser screen has the "strikethrough" property. In other words, there is a line running through each file and folder. In addition, if I hit VIEW to move to the Audio_browser1 screen, there is no text (no file/folder names) under each icon. This is driving me![]()
Sorry to state the obvious but did you set up RRConfig again correctly i.e. set the path to the correct music folder?Originally Posted by WxGuy1
My Vis wouldn't embed either and I thought I was going to have to switch to WinAmp 2.95. But I went into RRConfig and changed the Vis from the default "milkdrop" to "AVS Window" and WOW I have Embedded Tranparent Visualizations running on my Audio Player skin - COOL!!Originally Posted by damoru
Yeah, I set up RR to the correct music path (C:\MP3s\). The file names and folder names show up, but there's a strikethrough (like an underline, but through the middle of all text). I have no idea how that would get there, but it's there on the reinstalled version.Originally Posted by gbh
That's weird - can you still open those files and play songs? Did you try rebooting after setting up RRConfig?Originally Posted by WxGuy1
Try another skin like BMV and see if the strikethrough is there.
