Page 32 of 60 FirstFirst ... 222324252627282930313233343536373839404142 ... LastLast
Results 311 to 320 of 596
Thread: Release - MC2.0 Skin
  1. #311
    May 2005
    Quote Originally Posted by upspace
    the same here. latest flash and rr version but no album art - neither on the main screen nor in the box below the menu button in the audio player screen:-(?!??!
    Yeah, I still haven't been able to get album art to display correctly. I've tried everything I can think of, and nothing has fixed the problem. So, I'm just giving up on getting it to work. I have no idea what's preventing the flash stuff from working (I've installed everything, etc), but it ain't workin..
  2. #312
    Variable Bitrate Erwin's Avatar
    Mar 2005
    Quote Originally Posted by CubanAffection
    Here's my shot at it:
    Colors look a lot more vibrant on the screen itself. I'm new to this CarPC but I'm hoping to complete my first carpc project soon! If you have any suggestions please let me know, I'm all ears.
    What is the problem with the track no? I've got the same problem here.
    Quote Originally Posted by eduardovdr
    Apart from this matters, im having another issue, but this time with Freedrive.
    When I load Freedrive from RR, the windows task bar appears over your freedrive menu skin (picture to show what i mean). Task bar dissapears when I click on the bar, where u see "RoadRunner". What do i have to do to avoid this problem?
    I've got the same problem, but I solved it by editing the taskbar options. Press right mouse key on the taskbar and select 'properties', then deselect 'always show taskbar on foreground'. NOTE: Maybe it is called different in English (I have a Dutch Windows version).
    Hardware: Via Epia M10000, 512MB DDR RAM, 3,5" 40 Gig HD, slimline DVD-ROM & CD-R/RW, M1-ATX (PSU).
    Software: Roadrunner, Mapmonkey/Freedrive
    My Car PC project
    FD & MM voices
  3. #313
    May 2005
    Quote Originally Posted by Erwin
    Thank you so much. Problem solved!
    As for the album art not showing, I had the same problem. What I did was ERASE the whole RR installation and get the newst one available. Then put the MC2.0 skin and voila! it was working! Tell me it works for you guys too.
    Cheers!
    PD: posting in forums is cool when you get your problems solved after you did everything u could think of to get 'em solved by yourself
  4. #314
    Variable Bitrate proph's Avatar
    Aug 2005
    Little Elm, Texas
    Can someone post a sticky with all the latest software.
  5. #315
    Raw Wave
    Jun 2004
    On the beach
    Which latest software??? RR?? MC2.0??
  6. #316
    Low Bitrate DoubleC's Avatar
    Nov 2005
    ATX
    There is a sticky for all the RR Skins it's the one that says all completed skins can be found in here. Now I can't promise all the links work but don't see why they wouldn't.
    As for RR software Guino has like 20 gazillion posts in this forum that have his sig on the bottom just gotta find one of em. Or you could go to the post on the top that says 11/27 new changes to RR or something to that extent.
    Good Luck on your journey and drink lotsa fluids.
  7. #317
    Aug 2005
    Little Elm, Texas
    How about FreeDrive? I have the RR Skin with MC 2.0. I think its the 11/27, is that all thats needed to get Freedrive to work? Or does it have its own installation?
  8. #318
    Oct 2005
    Has anyone made an iG skin for this?
  9. #319
    Mar 2005
    I have a problem by implementing the CDRip plugin into the MC2.0 skin. In all other skins the CDRip plugin works correct, but in the MC2.0 skin the CDRip plugin has a problem finding the CD drive. It always displays the current MP3 playlist.
    How can this be solved?
    My Car PC project
    FD & MM voices
  10. #320
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    inspired by the zots skin
    I know the first screen has a low viewing area but fs button fixes that.
  1. mac style skin release...
    By btbe in forum RR Skins
    Last Post: 08-14-2007, 10:07 AM
  2. Release - FFS Skin beta 0.1
    By CdRsKuLL in forum RR Skins
    Last Post: 03-17-2006, 02:11 PM
  3. Flash RR Skin Beta Release
    Last Post: 01-15-2006, 08:48 PM
  4. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 08:28 PM
  5. New Skin - Spaced_Out for FrodoPlayer 1.08
    By WeeZyFellA in forum FrodoPlayer
    Last Post: 10-17-2004, 10:50 PM
