Page 35 of 60 FirstFirst ... 252627282930313233343536373839404142434445 ... LastLast
Results 341 to 350 of 596
Thread: Release - MC2.0 Skin
  1. #341
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by Enforcer
    This has been discussed, make sure you have the latest version of flash.
    Also
    check last line of guino's download page
    http://guino.home.insightbb.com/download.html
    Any one got the flash.zip file ? Its on the Mpug site which is down at the mo ?
    Also - The freedrive EXE that is in the skin zip file ( and this is to CDR ) is newer or older that 0.9b ?
    I want to add the speedo like you have on your screen shot but I'm not getting any where.
    Terran
  2. #342
    Raw Wave
    Jun 2004
    On the beach
    0.90 Full is newer.
    Just install the latest version of flash as the flash.zip doesn't have the latest version to get the speedo work.
  3. #343
    Jan 2003
    Quote Originally Posted by Gobby
    0.90 Full is newer.
    Get the same prob - flash8.ocx Crashes after a about 5 mins... even sooner with FD running in MC 2.
    Terran
  4. #344
    Raw Wave
    Jun 2004
    On the beach
    Any error messages??
  5. #345
    Jan 2003
    Yeh but was in the middle of the road at the time with the family. I'm going to try a thery out.. I've got the proper MSI installer for flash here frojm one of Gunios posts... its twice as big ( about 1.57 mb I think) .
    Now - I installed via the link on the first post over the net ( 700+ KB ) so I wonder whats different.
    Terran
  6. #346
    Jan 2003
    Quote Originally Posted by ccsnet
    Terran
    JFI - I've just tried the update and I think I got rid of the flash8.oxc issue but the error refers when in FD refers to rr.exe - I could not get the text file as it totaly hung but when I rebooted it did not do it.
    Will try tonight and report back.
    Terran
  7. #347
    Jan 2003
    Terran
    OK - Answer - the Full flash install fixes the problem so the Internet link on page 1 must only install some of the client. As soon as I can get the uploader working I'll post a link but its probably worth sticking on FD.co.uk or some thing.
    The only other prob I still have is that I cant get the speedo to show. GPS is running ( but possibly slow connecting as its BT ) and I have free drive hidden working... but when I have the main screen and touch it ( which I think is correct ) it just shows the normal pic.
    Lastly - heres a thought.... came from test drive and what Enforcer was requesting.
    Where the volume bar display is if you where on the main screen you could get that bar to flash three times when a camera is detected and then as your getting closer the bar could build up from green to red.... once past it then could reset to the normal volume bar ... what do you think ? ( PS all this with Audio Warnings and the data from FD )
    Terran
    EDIT ------->>> http://s01.11send.com/down.php?id=01060115911309663525 <<<------- This is the file... expires in 15 days from now
  8. #348
    aco
    aco is offline
    Oct 2005
    UK Yorkshire
    volume bar thingy sounds good but maybe a bigger chunkier bar at bottom for easy viewing, something you can see easily and quickly, without much effort, if you know what i mean, rather than having to focus on something smaller in the top left corner, then it could be applied to any page maybe.
    Andy
  9. #349
    Jan 2003
    Can some one help ?
    Can't get the speedo to work... GPS defintly running, FD Hidden / Freedrive running, sdk.ini has the correct entries, tap the screen and nothing....
    Am I missing some thing here ?
    Terran
  10. #350
    aco
    aco is offline
    Oct 2005
    UK Yorkshire
    i had same prom with new version you need to make sure that fdspeed=Roadrunner in the ini also for heading you need to add fdheaddeg=Roadrunner.
    hope this helps
    Cheers
    Andy
  1. mac style skin release...
    By btbe in forum RR Skins
    Last Post: 08-14-2007, 10:07 AM
  2. Release - FFS Skin beta 0.1
    By CdRsKuLL in forum RR Skins
    Last Post: 03-17-2006, 02:11 PM
  3. Flash RR Skin Beta Release
    Last Post: 01-15-2006, 08:48 PM
  4. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 08:28 PM
  5. New Skin - Spaced_Out for FrodoPlayer 1.08
    By WeeZyFellA in forum FrodoPlayer
    Last Post: 10-17-2004, 10:50 PM
