Page 36 of 60 FirstFirst ... 262728293031323334353637383940414243444546 ... LastLast
Results 351 to 360 of 596
Thread: Release - MC2.0 Skin
  1. #351
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by aco
    i had same prom with new version you need to make sure that fdspeed=Roadrunner in the ini also for heading you need to add fdheaddeg=Roadrunner.
    hope this helps
    Cheers
    Andy
    Cheers - Will do
    Terran
  2. #352
    Jan 2003
    Quote Originally Posted by Angelus
    Never done it terran, but in the time settings in rr config, set the time "HH:MM:SS AM/PM" to either long time or "HH:MM:SS".
    check the second page of post " RR 2-27-05... LATE Release (Fixes)"
    cheers
    Ang
    Duh - I should know this.... I was thinking the skin was wrong..
    Terran
  3. #353
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    finally stopped my lilli behaving oddly after a restart. It would flash on and off. With screen split left to right, and screen sort of wrapped so left showed right edge of screen... Funny thing is it would do it just be removing and re-inserting power lead from the lilli... Even if PC was on and not touched.
    It seems to be caused by MC2.0
    If I use another skin all is fine. Even if the other skin has flash components
  4. #354
    Jan 2003
    Quote Originally Posted by ShawJohn
    Refresh rate ?
    Terran
  5. #355
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by ccsnet
    Refresh rate ?
    Terran
    One cold lager every 30 mins.
    every 20 mins during summer
  6. #356
    Jan 2003
    Quote Originally Posted by Enforcer
    And one yard of Jaffa Cakes per Christmas ....
    Terran
  7. #357
    Aug 2004
    On the edge!
    refresh rate is always set at 60Hz for any res I use, and default 640x480 is 60Hz too
  8. #358
    aco
    aco is offline
    Oct 2005
    UK Yorkshire
    can you set the equiliser presets to whichever source your listening to eg; audio;rock, radio;pop, like you can in bmv2 .skin files.
    Cheers
    Andy
  9. #359
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    FreeDrive v1.0.. its coming :-)
    POI's now coded in as promised :-)
  10. #360
    Jan 2003
    Quote Originally Posted by CdRsKuLL
    Ooooooooo ahhhhhhhh
    Cant wait.
    BTW - Re MC 5 - had a thought
    How about when the main menu loads the buttons appear and spin from the top botton to the bottom on vertically length ways.
    Also when clicked they do the same animation just to give a little more feed back.....
    ( Was that a bas explination or did you follow ? )
    EDIT Like Plane and train time boards...
    Also can we have 4 pages availble of buttons ? I'm struggling on 3.
    Terran
  1. mac style skin release...
    By btbe in forum RR Skins
    Last Post: 08-14-2007, 09:07 AM
  2. Release - FFS Skin beta 0.1
    By CdRsKuLL in forum RR Skins
    Last Post: 03-17-2006, 01:11 PM
  3. Flash RR Skin Beta Release
    Last Post: 01-15-2006, 07:48 PM
  4. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 07:28 PM
  5. New Skin - Spaced_Out for FrodoPlayer 1.08
    By WeeZyFellA in forum FrodoPlayer
    Last Post: 10-17-2004, 09:50 PM
