Results 1 to 10 of 10
Thread: flash movie like a button?
    Dec 2005
    Italy
    wass'up homies?
    Is possible use a flash movie like a button?
    I made a new skin and i used flash logo but i would like use it like a button...
    Jul 2004
    NL, Druten
    yes you can.. just place the button above the flash movie :P
    Dec 2005
    Italy
    i tryed to do this but the button don't work
    Where is my mistake??
    FLAC Spaghetti's Avatar
    Jul 2003
    Spagcave, in da UK Today's phrase: J'aime Alizee
    Post your code and someone might tell you!!
    In da club....
    ALIZEE WANTS YOU.....
    (\__/)
    (")_(")
    Bunny's first poo
    __ U
    Dec 2005
    Italy
    You are right! I'm not very expert...
    MEDIACAR Skin
    MEDIACAR F-CNS(800x600Stretched)"audioplayer"skinskinskinskin skinskinskinskinskinskinskinskinskinskinskinskinsk inskinskinskinskinskinskinskinskinskinskinskinskin skin
    audio_player_off.jpg,audio_player_off.jpg,audio_pl ayer_on.jpg,audio_player_down.jpg
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B,684,344,110,105,"DOWN",
    B,684,119,110,105,"UP","up"
    B,4,228,110,105,"NEXT",
    B,458,516,210,68,"VOL+",
    B,130,516,210,68,"VOL-","vol-"
    B,4,119,110,105,"PREV","down"
    B03,4,5,110,105,"PLAY","play"
    B12,698,470,79,97,"EXIT","Exit"
    B,684,230,110,105,"SEARCHLIST",
    B16,684,5,110,105,"SHUFFLE/REPEAT","shuffle/repeat"
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L08,10,130,410,020,255,255,255,20,"Arial Narrow:B","PLAYLIST","Playlist"
    L05,290,5,100,040,255,255,255,17,"Arial Narrow:B","KBPS","Track bitrate"
    L06,380,5,100,040,255,255,255,17,"Arial Narrow:B","KHZ","Track freq"
    L08,10,160,070,030,255,255,255,15,"Arial Narrow:B","STATUS","Status"
    L02,90,160,050,040,255,255,255,15,"Arial Narrow:B","CURRENTTRACKTIME","Current track time"
    L01,150,160,050,040,255,255,255,15,"Arial Narrow:B","TRACKTIME","Total Track Time"
    B,4,465,110,105,"GPS","gps"
    /, F, x, y, w, h, Movie name
    F,4,465,110,105,"earth.swf"
    B,344,516,110,67,"LIST","list"
    B,4,344,110,105,"STOP","stop"
    L09,150,05,130,030,255,255,255,18,"Arial Narrow:B","TIME","Time"
    L10,10,05,130,030,0,255,0,18,"Arial Narrow:B","DATE","Date"
    /, I, x, y, w, h, Code;INDICATORCODES
    I,738,16,26,37,"SHUFFLE"
    I03,708,16,26,037,"REPEAT"
    /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, played color R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name
    S01,152,60,496,380,255,255,255,000,000,000,255,245 ,000,000,000,000,255,0,0,TRUE,20,
    /, A, x, y, w, h, color;RGB
    A01,149,20,503,380,000
    END
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Your Flash object would have to be Transparent for the button to be clickable... other than that you'd have to make the FLASH movie execute the command using the fscommand in flashscript. Check the sample.fla file in the BMV2 skin as an example.
    Ride Runner RR's Myspace
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    To make the button, you can just use the rectangle or circular shape tool and set the alpha of the shape to 0. That way there is a hit area for your button and you can see through it at the same time.
    Otherwise you can load the earth.swf into a container sprite of a separate flash movie and use the earth.swf as a button.
    Dec 2005
    Italy
    I have one image.swf of the globe that rotates and i want open MM in RR but if i use:
    on (release) {
    fscommand("exec", "xxxxxxxxxxx.exe");
    for xxxxx.exe what do i put??
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I don't know what you're trying to do but:
    does nothing... the first parameter needs to be a RR COMMAND (as in skin commands.txt) and the second parameter is used on very RARE situations (i.e. to simulate Up/Down mouse events)...
    If you want to run something then look at the RUN or LOAD command for RR and use: fscommand("RUN;C:\...\MM.exe", "");
    Dec 2005
    Italy
    thanks guino but i think that I am too much stupid.....
    i'll put one normal static image.
  1. sending keystrokes to flash?
    By Nitrov8 in forum Road Runner
    Last Post: 04-07-2006, 01:51 AM
  2. Replies: 10
    Last Post: 10-31-2005, 05:17 AM
  3. Can a hovering button be implemented ?
    By tolisn in forum Road Runner
    Last Post: 10-15-2005, 12:11 PM
  4. Panasonic Slot Load DVD Player....Lost the button
    By Cheekz185 in forum General MP3Car Discussion
    Last Post: 10-11-2005, 02:24 PM
  5. Working w/ Flash??
    By emayers04 in forum MediaCar
    Last Post: 06-01-2004, 06:53 PM
