Results 1 to 9 of 9
Thread: Helping with finding alpha blending option
    Variable Bitrate pcfreak's Avatar
    Dec 2005
    Freeport, IL.
    It seems many people are having problems with the AVS transparency. Here are a few pics to help with that. Hope it helps to solve your problems. As you can also see in the pics, I have added a pic of my ride to the AVS window. This is what you get when you just mess around with things. You get the results you didn't know that you wanted....lol Any ways, I hope this helps.
    Peace
    Now, right click on your vis and pick AVS editor. On the next window pick the settings tab and choose display. This is where you find the alpha blending option. This is obviously only available for WindowsXP users. Good luck and remember, if you go editing a lot of things in here and screw it up, just reload the *.avs file. Do not save it unless it is the way you want it or you know how to get it back to where you want it.
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Just what I needed, saved me some time with the button
    Dec 2005
    Freeport, IL.
    Quote Originally Posted by ShawJohn
    Helping one person makes it worth the time it took to post. Glad I could help bud.
    Peese
    Aug 2004
    On the edge!
    Just one problem now. Got my vis running as normal when standalone, but when in RR its still Transparent
    ...Anyone?
    Aug 2004
    On the edge!
    BUMP!
    Why is my Vis still transparent in RR when its not in Winamp?
    Can't find any options in the RR ini files or skin files to influence this.
    Dec 2005
    Freeport, IL.
    BUMP!
    I think I remember having that same issue with mine way back but I cheated to get mine back. The one in my car was doing that but the one in the house wasn't, so I copied both the Road Runner and the Winamp directories over to the car and it fixed it..... hahaha hey what ever works right?
    Dec 2005
    Freeport, IL.
    Did you set it up as a wallpaper or screensaver in RR?
    Aug 2004
    On the edge!
    How do you mean?
    Its just set as being the Winamp AVS Gen vis...
    Dec 2005
    Freeport, IL.
    How do you mean?
    You can set your visual as wallpaper or screen saver. I thought maybe you had done that but I guess not. There is nothing in rrcongif for these options, you have to do that all manually. If you search the rr forum you should find posts for doing these.
  1. How to screencap alpha blending???
    By deadweasel in forum Software & Software Development
    Last Post: 07-03-2004, 07:22 PM
  2. helping finding cardbus
    By cubanmoses in forum General Hardware Discussion
    Last Post: 06-20-2003, 12:19 AM
