AFAIK its the latest version from here...
I don't know if it does it in other skins as I haven't tried any. It seems to lock up as soon as the frame borders are crossed with the mouse pointer. The whole PC locks up and even Task Manager will not respond. Only thing that works is a hard reset.
If I turn off mouse over effects its fineNo Biggie really, its just annoying. Haven't really been modding any skins lately to find out more... If anything else relevant happens I'll let you know.
Yeah, I have tried it on both my home PC's and a works PC and they all behave the same. Its probably something to do with the VB installations on those PC's. I'll have to re-install when I get a chance to test.
LinkBack URL
About LinkBacks
... Y slider.......I thought I fixed that in the last version.......What version are you using? May be your objects file. Check the objects.txt file. I'm not sure if it had to do with the non drawable objects. Try redownloading the program again. I thought i had that error fixed months ago, but its been months since ive worked on it so maybe it is still a bug. Also try removing the number from it just use Y and not Y01. Hope this helps.
