Page 4 of 24 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 232
Thread: RRSkinEditor BUGS / FIXES / COMMENTS / CURRENT PROGRESS OUTDATED
  1. #31
    May 2005
    Vienna, VA
    profit, this may seem like a lot of work so ignore this request if you want. I'd like the ability to export a skin to a new resolution, for eg. from 800x480 to 800x600. What SkinEditor should do is scale all the coordinates/widths/heights to the new resolution.
  2. #32
    FLAC J187's Avatar
    Nov 2004
    Boston
    I'm trying the Alpha now. It works good so far. I think it's fine with the way it switches. I still have testing to do, my only suggestion for now, would it be possible to make it so that if you highliht a button on skineditor screen, then open virtual pad the text corresponding to that button would be highlighted already??
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
  3. #33
    FLAC J187's Avatar
    Nov 2004
    Boston
    Ok, everything looks ok to me, the check boxes are a good idea as far as how to handle to one behind the other problem.
    Please help.
  4. #34
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    Quote Originally Posted by b8bboi
    Cant you just change the RR resolution under INI settings. Or do you want to physically change the resolution then have the editor auto move all the buttons?
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
  5. #35
    May 2005
    Vienna, VA
    Quote Originally Posted by pRoFiT
    Yes, I can do that but most of the time I'd rather resize all my images in Photoshop to the new resolution since it'll look better that way (less artifacts). Plus, commands like LoadIMG don't work correctly in resized skins.
    Yes, that's what I'm looking for.
  6. #36
    Apr 2005
    Fresno, CA
    Quote Originally Posted by J187
    Yah I thought about that too. Wouldn't be to hard to do. Did you like the save button or would it be easier to just have it auto update when you switch back and forth. I could put another option to autosave or manual save.
    I also had a properties box i was working on, but it didn't look right so i pulled it out on the alpha. not sure where im going to put it.
    Check boxes.....they select sometimes when you dont want them too but i think that will be a mild inconvienence to not being able to select objects. I may have to move them outside of the listbox but we will see if i can get it to work with them in there.
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
  7. #37
    FLAC J187's Avatar
    Nov 2004
    Boston
    The save button kinda messed me up at first, after, I didn't mind having to use it. However, I can't see any reason why auto save wouldn't be good too. Now, when I press save button on virtual editor, does that save the changes to the skin, or just apply the changes to show me in the editor? If there was a way to auto apply the changes without saving the skin file it would super helpful to be able to see what you just did without actually saving over the skin file.
    I was just skinning a couple days ago where I made about 15 of the exact same buttons, I would have LOVED the virtual editor back then - I actually closed down skineditor and did the work in microsoft word so I could take advantage of copy/paste.
    EDIT, the more I'm using the virtual, the more I'm realize how nice it would be to auto highlight the text based on what button is selected when switching. it would even help beginners to Identify what the text should look like for each object and understand.
    Please help.
  8. #38
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    That would be a cool feature indeed.
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
  9. #39
    FLAC J187's Avatar
    Nov 2004
    Boston
    Another small change that would be nice, assign some unique Keys to the objects that are available, so that when you click on a box and it comes up T01, you don't know whether its a touchwheel or a textbox until you look further. Then there are ALL those Ss. Playlist, Dir List, slider, etc.
    Please help.
  10. #40
    Apr 2005
    Fresno, CA
    I was planning on having a properties box instead of the add object box/edit object box. Where when you select an object all the properties would come up ie. x,y, type, command, etc. And would be editable. I could have the correct type shown at the top
  1. Some notes on my carputer's progress. Comments? *WITH PICS*
    By Bailey in forum General MP3Car Discussion
    Last Post: 01-17-2005, 12:53 AM
  2. MediaEngine Development Progress Update
    By CarComp in forum Media Engine
    Last Post: 01-07-2005, 01:53 PM
