Page 8 of 24 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 232
Thread: RRSkinEditor BUGS / FIXES / COMMENTS / CURRENT PROGRESS OUTDATED
  1. #71
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by Gobby
    Unless you had RRSkineditor talk to RR via the SDK and send a RELOADSKIN command whenever a change is made, that way RR will reload the skin on the fly, just an idea.
    now thats a good idea. And much easier to do. When you save the skin, have skineditor send the RELOADSKIN command! nice.
    beer replenishment fund
    mp3car live search
  2. #72
    FLAC J187's Avatar
    Nov 2004
    Boston
    Quote Originally Posted by liquid_smoke
    J187 said something about autohighlight option being great, im not sure if that was a request or if was something that is suppposed to be working. I dont see any highlights though.
    Smoke, it was my request earlier to autohighlight and profit met that request very shortly after, go back to post 45 and download the new link he put there, that version autohighlights the text in the virtual as soon as you switch from skineditor when you have an object selected in skineditior.
    As far as what you said about the full preview being a bit much, I agree very much with you, I felt that way from the start, I didn't want to dismiss anyone elses ideas so I kinda tip-toed around it, but I've always thought the only really usefull preview feature would be a font size and color. I sometimes edit font size and color in my car on skineditor where I don't have F5. Also, its just much nicer to see the font right away.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
  3. #73
    Raw Wave
    Jun 2004
    On the beach
    Profit:
    Just add the modSDK.bas and modcom.bas to RRskineditor then add the commands below in the relevant places in the main form:
    Code:
    Option Explicit
    Private Sub save_Click()
        'save code
        'Send the reloadskin command on saving
        COMSend "RoadRunner", "RELOADSKIN"
    End Sub
    Private Sub Form_Load()
        'Prepare to receive messages
        COMHook Me.hwnd
    End Sub
    Private Sub Form_QueryUnload(Cancel As Integer, UnloadMode As Integer)
        'Unhook message API
        COMUnhook Me.hwnd
    End Sub
  4. #74
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    One more thing thing that I have noticed is that it will not save the /DISCARDABLE line in the virt notepad...
    Other than that i have been using this new version heavly, and all I have to say is, WOW,WOW..talk about streamlinning the whole process...
    Thanks very much for adding all these recent features....
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #75
    FLAC J187's Avatar
    Nov 2004
    Boston
    Today I cranked out a bunch more files of my skin. After extensive use I find that I am using the virtual quite a bit. I am also not using the auto update, because I have accidentally made changes that I wished to discard and I actually like having to save manually before returning to skineditor.
    Please help.
  6. #76
    Dec 2005
    I'm not sure if this has been requested or been update on th RR Editor, but I love to see more commands or codes such as Clip"C" and others that are not available on the pop-up menu to be added.
  7. #77
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    Sweet. I think i can implement and undo redo with out to much head banging. I'm just going to borrow someone else's text editor code and then just capture all changes. Should be easy . But yah i thought the option to turn on or off the auto update is good too.
    Blue_zx3: /DISCARDABLE is working now i need to do some more checks but will try to release it tonight sometime. I forgot about that one. I was going to fix it a couple weeks ago and got side tracked with a personal project. Anyways should have new link up tonight. In fact i dont think i checked to see what happens when you switch skins from the skin menu.
    Gobby thanks. I was thinking about embedding RR into another side form within RRSkinEditor. Im kinda worried about what would happen if someone was using 800x600 on there system while using the editor and RR embeded. Might not be enough room to see RR. Maybe ill just do what you said and have a button that refreshes Road Runner. I will have to play with it and see what i can get to work.
    Thanks everyone.
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
  8. #78
    Apr 2005
    Fresno, CA
    Quote Originally Posted by drewdizzy
    Latest version should have clip as an option. I updated the objects.txt file to match Guinos lastes RR release. About two weeks back.
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
  9. #79
    Apr 2005
    Fresno, CA
    Okay another update. Havn't had time with the undo/redo feature but I will get there. I did have time to fix /DISCARDABLE. Currently the editor disregards all / comments which is what /DISCARDABLE looked like. So I fixed that. I would really like to go back and have it save all /comments Because someone put them there for a reason it should really put them back when saving.
    Anyways here is alpha V0.3.016
    http://home.comcast.net/~cstrachn/RRSkinEditorAlpha.rar
    I guess I shouldn't call it alpha. Alpha is normally not subject to outside testing. Next version i will switch to beta with undo redo hopefully and some kind of properties box.
  10. #80
    Raw Wave
    Jun 2004
    On the beach
    Quote Originally Posted by pRoFiT
    Could always have a floating button that swaps shows/hides each one, just an idea.
  1. Some notes on my carputer's progress. Comments? *WITH PICS*
    By Bailey in forum General MP3Car Discussion
    Last Post: 01-16-2005, 11:53 PM
  2. MediaEngine Development Progress Update
    By CarComp in forum Media Engine
    Last Post: 01-07-2005, 12:53 PM
