RRSkinEditor BUGS / FIXES / COMMENTS / CURRENT PROGRESS OUTDATED
Well Guino added a ton of things to the editor to keep up with RoadRunner. Check out his thread here http://www.mp3car.com/vbulletin/rr-s...or-v0-5-a.html
Okay This should make it easier to find the current version of RRSkinEditor. If anything changes I will make it known in this first post. Except for the occasional post whoreing in my own thread :)
First off: Lbooker Wrote the original version of this software, Guino added some functionality and then I stumbled onto it. I have been fixing and adding functionality to this program for a couple months now. So I'm getting the hang of where everything is.
Second: This thread is for RRSkinEditor only. Bugs in the program. Any functionality that you may want or feel would make it easier to use. Or things you hate about it would be okay too.
Okay here is the good stuff.
Current Version of RRSkinEditor With new Virtual Editor :) V0.3.019
http://home.comcast.net/~cstrachn/RRSkinEditor.rar
Beta Version of RRSkinEditor With new Virtual Editor :) V0.3.024 Use UNDO/REDO at own risk ;)
http://home.comcast.net/~cstrachn/RRSkinEditor024.rar
Current Source of RRSkinEditor found here
http://home.comcast.net/~cstrachn/RR...itorSource.rar
Source may be behind a couple versions
Microsoft VB Runtime Files Version 6.0 sp5. May be needed to run RRSkinEditor
http://www.microsoft.com/downloads/d...D-CDF2D29A79D5
Current Suggestions that I might work on are:
JohnWPB: Add PNG support to editor. 4-15-2007 <-- will look into.
4-22-2007: working without transparency will need to investigate the png format some more.
Royn: Add Ctrl Click on buttons to open the skin it points to when the command LOAD is used. <-- still thinking about this one :)......Probably use the update RoadRunner skin command to reload the skin in RoadRunner
1-3-2007: Still not implemented
liquid_smoke: Enable/Disable Objects from displaying there box. That way you can click on an object that is behind something else without selecting something else. <-- started on this one. Got side tracked with virtual editor and some other bugs. Still working on it.
1-3-2007: Added to version 0.3.020
Display image attached to an IMG object <-- next on my list, somewhere on my list ;)
Virtual Editor with Undo/Redo commands Directly embeded into RRSkinEditor <-- Virtual editor is working but needs improvement still.
Properties Box: Like in photoshop or frontpage. Would get rid of the double click to adjust settings. Click on an object and the Properties Box updates to reflect currently selected object. <-- started to work on this but can't find the best way to do it yet.
1-3-2007: Still on my list of things to do
Fixes:
Version 001-005
Added Flash playback ( kind of buggy, need to redesign this section )
Fixed crash with the up down order of object buttons
Version 006
Moved over the command [...] button
Added move objects with mouse
Version 007
Added Object Adjustment with mouse
Version 008
Added create new skin menu button
Version 011
Added x1y1 on slider to match xy when moving with mouse ( need to go back and add 2 boxes for this feature)
Fixed crash with adding Y slider style (my bug)
Version 012
Added default in the ini file to cause the program to use program directory for skin locations when first installing.
Added Auto focus to done on all objects to make it faster on objects that don’t need more then xy coordinates
Version 013
Fixed auto focus bug that caused curser to go to done when ever the command box changed.
Version 014
Fixed mouse adjustment when zoomed in or out
Fixed y slider style crash when pressing up/down/left/right
Version 015
Fixed GENERAL.INI failure during save when creating a new skin or skin folder with no GENERAL.INI file.
Version 016-017 of RRSkinEditorAlpha - okay beta
Added Virtual Editor
Has autosave configurable through settings
Autohighlight of object when switching to virtual editor.
Added compatability with /DISCARDABLE as a skin setting
Version 018 RRSkinEditor
Fixed crash when adding any non drawable items such as y - slider, IDL, TMR, and V - visability.
Version 019 RRSkinEditor
Fixed crash when opening skins with y - slider, IDL, TMR, and V - visability
I guess I should have saved and then reopened
Version 020 RRSkinEditor [1-3-2007]
Right click to move objects
Lock/UnLock buttons added for easier selection of complicated skins
Undo/redo added to the VirtualEditor only
Text will adjust to zoom command
Comments added as objects - can edit in editor
added /INC to objects.txt
/IMG will display image at x,y location
DISCARDABLE spelt right ;)
Version 021 RRSkinEditor [1-4-2007]
Fixed comments highlighting objects
Fixed crash when selecting comments
Fixed bug where objects next to comments dont come out as brite as the other yellow objects :)
Version 022 RRSkinEditor [1-5-2007 1:00am]
Vixed copy paste key commands in virtual editor.
Switched auto lock off and now have it default to unlocked objects.
Version 023 RRSkinEditor [1-15-2007]
Switched auto lock off comming out of virtual editor
Switched drag object back to left click!!!!! some people are never happy :)
Soon to be selectible left or right click for the leftys out there.
added auto space between groups of objects. Make it easier to read. Plus it used to do that before i added comments :)
Version 024 RRSkinEditor [4-22-2007]
Added PNG support for layout.
NOTE: Transparency will be filled with white by default. Until further investigation into PNG. I may use Guinos GDI+ code. Once i've had time to understand how he is doing it.
Please feel free to send in the BUGs so I can help the mp3car community. And Guino of course ;)
