hah which button is the visualizers....i cant get an visualization in music...what button is it
I was using LS 3.0 and now LSX !
Everything up and running well....except my Phone....Phonecontrol is working outside and inside the skin. But the Reload Button in LSX-Phoneskin doesnt work for me...there is no reload of Phoco.
And one more Question:What is the headphone icon meant to do, cause also nothing happens if pressed???
BTW did someone has already covered this or has the same Problem:
If i load the Visuals in Fullscreen (i think press the time in menu)
it wont let me get back to the menu ( no ESC with Touchscreen)!
Only minor problems ... Nice SkinTHX
Oh and perhaps LS can talk to CDR to get that Speedo used in his ME2.0 skin...looks far better....No offense ...only a suggestion...![]()
the visu button in the audio player is on the top right of the screen, its the icon that looks like a Spectrum analyzer, and on other screens where need be its where the date is.
Clickin the TIME has a different function.
It runs MMB.exe whos only purpose is to invoke MouseWheelInput
MMB.exe is located in Road Runner\LSTOOLS\SCRIPTS\MMB.exe
So make sure you do have LSTOOLS located in the root of RR install. Or you will have issues as with the current release of RR, if RR cant find an exe you will loose touchscreen support.
As for running VISU fullscreen and not being able to exit back to RR, you should be able to exit fullscreen by double clicking the visualization.
and as for speedo's, i havent checked out the speedo in ME2.0 (but ill take a look). But there is a NEW speedo that i will be releaseing thats far more practicle than the current one. Although... it currently isnt ment to be used with LSX(at least not in areas other than the GPS screen) its for a new skin im working on, but i think people will find it a lot better.
beer replenishment fund
mp3car live search
Hi ls,
i'm using navigator 4.3as per mv's post 23/24 - i've copied the gps software locations to exectble but my gps software just opens as a seperate window ... what am i doing wrong?
love the skin btw!
this is the amend i made;
/path to GPS............................................... .........{ path to your gps application }{ window title}
"GPS","LOAD;EXTERNAL_GPS.skin;RUN;C:\Program Files\Infomap Navigator\Navigator.exe"
/path to GPS, use "GPSFS2" as the code for the "FULL" button on EXTERNAL_GPS.skin if you want fullscreen with menu on bottom
"GPSFS2","LOAD;EXTERNAL_GPS_FS2.skin;RUN;C:\Pr ogra m Files\Infomap Navigator\Navigator.exe;Navigator"
/....................-path to GPS and EXITFS utility..........{ path to your gps application }{window title}
"GPSFS","LOAD;EXTERNAL_GPS_FS.skin;RUN;C:\Prog ram Files\Infomap Navigator\Navigator.exe;Navigator||RUN;LSTOOLS\SCR IPTS\EXIT_FS.exe"
any ideas?
cheers
cliff
Hey Pheebs67 perhaps you missed the window title in the first one....:
"GPS","LOAD;EXTERNAL_GPS.skin;RUN;C:\Program Files\Infomap Navigator\Navigator.exe;Navigator"
Just a guess....maybe it works...![]()
yeah, looks like you missed the window title in the first one, "GPS"
The other two are only accessible from the initial gps screen
mp3car live search
OK then - Added the window name (sorry I missed this - I'm still new to all this!) but this still doesn't work ... (it might be worth mentioning that I've tried several skins and none take to embedding this app very well)
Any other ideas?
since you're new, you need to read this.
How do I setup my GPS Application ?
Hi liquid_smoke
LSX is the Best RR Skin that i have seen. I use it on my Car and it works fine.
Is it possible to download the PSD File for the MENU2.skin ?
I need only Musik,Video,NAV,and Phone Icons on this Screen. And want to change the Icons NET and Game with Icons for Calculator and Notepad.
This would be very helpfull.
ill see if i can find the psd file for that menu, i may have to recreate it.Originally Posted by neuwacom
mp3car live search
