Page 12 of 36 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 111 to 120 of 356
Thread: LSX....formerly LS3.0
  1. #111
    FLAC djmickyg's Avatar
    Feb 2004
    not sure if its come already, had a look thru the tread already
    im having a play with this skin and using the mouse wheel imput config in ur zip..
    is anyone using this having truble pressing any buttons in RR when the mouseinput program is opened??
    no buttons at all work when its open.. ??
  2. #112
    Feb 2004
    been tring to get freedrive working
    i think i did alright sofar
    i made a nme gps.skin
    replace the one in the skin folder with this one..
    and then edit the ExecTBL file in the skin folder and put some "/"'s infrom of the igidance lines
    eg
    /path to GPS............................................... .........{ path to your gps application }{ window title}
    /"GPS","LOAD;EXTERNAL_GPS.skin;RUN;LSTOOLS\SB2.9\SK INbedder.exe;SKINbedder"
    /path to GPS, use "GPSFS2" as the code for the "FULL" button on EXTERNAL_GPS.skin if you want fullscreen with menu on bottom
    /"GPSFS2","LOAD;EXTERNAL_GPS_FS2.skin;RUN;LSTOOLS\S B2.9\SKINbedder.exe;SKINbedder"
    /....................-path to GPS and EXITFS utility..........{ path to your gps application }{window title}
    /"GPSFS","LOAD;EXTERNAL_GPS_FS.skin;RUN;LSTOOLS\SB2 .9\SKINbedder.exe;SKINbedder||RUN;LSTOOLS\SCRIPTS\ EXIT_FS.exe"
  3. #113
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by djmickyg
    Do you have the LSTOOLS folder in the proper location?
    when you click any of the MWI buttons inside the skin, RR tries to load this file
    LSTOOLS\SCRIPTS\MMB.exe
    if it can not find the file, RR will stop responding to mouse clicks (known bug in RR)
    To test this out, located the file above and run it (while you have MWI open).
    If it works then there is something wrong with your paths.
    beer replenishment fund
    mp3car live search
  4. #114
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    Wink
    Quote Originally Posted by liquid_smoke
    Yes, it drive me crazy for a while
    By the way, Liquid i just wanna say : you did it again ! Your skin is the best! You Rock
    Thanx a lot for your job
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
  5. #115
    Feb 2005
    Italy
    Take a look here..........
    Just discovered....
    When i launch iGuidance with SKINbedder after an MSOffice application, the following message appears......
    Any ideas???
    Fabio
    Travla C134
  6. #116
    Aug 2003
    Chicago
    hum, thats very odd. It looks like its trying to find iGuidance inside your OFFICE install dir. Half the error message is in another language too. I would double, tripple check all your paths. Does this happen if you launch skinbedder standlone (not using RR)
    mp3car live search
  7. #117
    Newbie WinoOutWest's Avatar
    Feb 2005
    Vancouver, BC
    speaking of odd problems, here's one for ya:
    If I cold boot and run RR everything comes up fine. If I launch iGuidance it does embed correctly. So I exit iGuidance and come back in and it is fine. Coupled with this I loose my touchscreen functionality. (mouse still works). If I hibernate and come back in everything is fine. Touchscreen works fine and if I launch iguidance it comes up perfect. This is consistently epeatable on cold boots.
    Any ideas?
  8. #118
    Aug 2003
    Chicago
    Quote Originally Posted by WinoOutWest
    Any ideas?
    Can you post the contents of both of your ExecTBL.ini files. The one inside the skin folder and also the one inside the root of RR.
    mp3car live search
  9. #119
    Aug 2003
    Chicago
    update 1 uploaded, check first post for link
    mp3car live search
  10. #120
    Feb 2005
    Italy
    Translation of the other half error message : Unable to find the path specified.
    IN RR : If i don't launch office before, all is right, 100% OK
    OUT RR : If i launch office before, all is right, no error messages...
    May be a problem induced by RR?
    Fabio
    Travla C134
