Page 13 of 36 FirstFirst ... 34567891011121314151617181920212223 ... LastLast
Results 121 to 130 of 356
Thread: LSX....formerly LS3.0
  1. #121
    FLAC djmickyg's Avatar
    Feb 2004
    Quote Originally Posted by Mr.Fabio
    Yes, it drive me crazy for a while
    By the way, Liquid i just wanna say : you did it again ! Your skin is the best! You Rock
    Thanx a lot for your job
    wel i figured out why it was going it for me
    the FreeDrive Skin i made. i use CROP around the app square
    so it was taking the focus off RR
    i removed that line from the skin and she works all good
    hope that makes sence?
  2. #122
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Translation of the other half error message : Unable to find the path specified.
    IN RR : If i don't launch office before, all is right, 100% OK
    OUT RR : If i launch office before, all is right, no error messages...
    May be a problem induced by RR?
    thats is very odd. The first thing i would check if i got a similar error message. Look at the ExecTBL.ini file and check the GPS paths and make sure none of them are weird. Look at RRConfig.exe and check GPS section and make sure all paths are correct. Also make sure your window names are correct.
    what program is creating that error box?
    I have office installed also, basicly in the same path as you but in english. I cant think of any other reason why this would happen other than a bad path being called somewhere.
    how do you have your GPS setup, are you using IG? also, you can post your ExecTBL.ini file and RR.ini files, ill take a look at them and see if anything is wrong.
    beer replenishment fund
    mp3car live search
  3. #123
    Aug 2003
    Chicago
    Quote Originally Posted by djmickyg
    well that explains a lot. You should of said in your first post you were having a problem with a custom screen you made.
    also, not sure if you knew or not, but if you used LS3.0 there is freedrive skin available that can be used with LSX. I also plan to update it very soon.
    Can you post a screen shot of the screen your made for freedrive?
    mp3car live search
  4. #124
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    Quote Originally Posted by liquid_smoke
    The error appears only if i run Word, Excel or Outlook embedded in RR before iGuidance (SKINbedder).
    Take a look to the my launch commands, RR.ini and ExcTBL.ini
    However is not very important
    Attached Files Attached Files
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
  5. #125
    Newbie WinoOutWest's Avatar
    Feb 2005
    Vancouver, BC
    Can you post the contents of both of your ExecTBL.ini files. The one inside the skin folder and also the one inside the root of RR.
    btw: I meant to say it iGuidance DOESN'T embed properly from a cold boot. It comes up with the file menu. So I shut down iGuidance, back to the main RR menu and back into iGuidance and it embeds properly. And then it will lose the touchscreen input until I return from a hibernation.
    THis is in the root:
    "QUIT","SendMsg;RRCDRip;showplugin||bye"
    "BYE","QUIT"
    /, Set Bellow the Path to the CDRip plugin (if used)
    "CDRIP","PLUGIN;RRCDRip;D:\VBStuff\Road Runner\CDRip\CDRip.exe"
    /, You can add commands to execute before suspend
    /, and after resume, using the codes bellow:
    "ONSUSPEND",""
    "ONRESUME",""
    "ONFILECLICK",""
    "ONDIRCLICK",""
    "ONPLCLICK",""
    "ONDLCLICK",""
    "ONPBCLICK",""
    and this is in the skin folder:
    / turn off word wrap to best edit this file
    / a forward slash at the begining of any line tells RR to ignore that line of text.
    /path to GPS............................................... .........{ path to your gps application }{ window title}
    "GPS","LOAD;EXTERNAL_GPS.skin;RUN;LSTOOLS\SB2.9\SK INbedder.exe;SKINbedder"
    /path to GPS, use "GPSFS2" as the code for the "FULL" button on EXTERNAL_GPS.skin if you want fullscreen with menu on bottom
    "GPSFS2","LOAD;EXTERNAL_GPS_FS2.skin;RUN;LSTOOLS\S B2.9\SKINbedder.exe;SKINbedder"
    /....................-path to GPS and EXITFS utility..........{ path to your gps application }{window title}
    "GPSFS","LOAD;EXTERNAL_GPS_FS.skin;RUN;LSTOOLS\SB2 .9\SKINbedder.exe;SKINbedder||RUN;LSTOOLS\SCRIPTS\ EXIT_FS.exe"
    /path to PicViewer.NET download app at http://www.phoco.net and install to default dir which should be same as below
    "PHOTO","RUN;C:\Program Files\PictureViewer.NET\PicViewer.NET.exe;PicViewe r.NET"
    /path to Mobile Emulator 2.0c download app at http://thequiltcupboard.net/mobileimpact/download.htm also see this thread True Touch Screen Friendly All Nintendo/Sega Emulator
    "GAMES","LOAD;N64.skin;RUN;C:\Program Files\Mobile Impact\Me.exe;Game Emulator"
    /path to RRConfig.exe
    "CONFIG","RUN;RRConfig.exe;RRConfig"
    /path to mousewheelinput utility download app from http://www.phoco.net
    "MOUSEWHEELINPUT","RUN;LSTOOLS\SCRIPTS\MMB.exe "
    /set weather you have xm radio or sirrus radio, default is XM, if you have sirius remove the forward slash and put one infront of XM
    "SAT","XM"
    /"SAT","SIRIUS"
    /This is for the circle button in the audio player screen, right of the battery meter, by default it pauses RR and mutes the wave line.
    "CUSTOM1","PLAY||RUN;LSTOOLS\LINE\TOGGLEWAVE\LineT oggle.exe"
    /weather sat images.... DONOT edit any of the below text
    "WEATHERSAT","RUN;LSTOOLS\WEATHERSCRIPTS\WEATHER.e xe||LOAD;WEATHER_IMG.skin||LOADIMG;24;76;145;309;w eatherbar_off.gif;OUT||LOADIMG;24;76;145;309;weath erbar_on.gif;ON||LOADIMG;24;76;145;309;weatherbar_ off.gif;OFF||LOADIMG;24;76;145;309;weatherbar_on.g if;DOWN"
  6. #126
    Jul 2005
    SD, CA
    full screen vis
    i got the visu working in LSX, but i have yet to figure out how to make the vis fullscreen. I loved this feature in LS 3.0 and was sad that it didn't exist in LSX but it looks like i may have been mistaken.
  7. #127
    Feb 2005
    Italy
    Simply double click on the visu while playing, should work....
    Fabio
    Travla C134
  8. #128
    Aug 2003
    Chicago
    ok, thats a key piece of information that you didnt state before. I was not aware you were embeding OFFICE in RR. That probably explains why its looking in your office dir for IG. The issue here im guessing is SKINbedder and or RR embeding multiple apps at the same time (on different screens).
    Generaly i make it a point to only have ONE app embeded in RR at any given time, there seems to be issues otherwise. Example, you'll note that when you leave the WEB screen, it will automaticly close the embeded browser and not minimize it. I suggest you setup office the same way.
    This gets rid of any issues with similar window names, and application focus.
    ill take a look at the files though, and see if anything sticks out.
    mp3car live search
  9. #129
    Aug 2003
    Chicago
    Quote Originally Posted by WinoOutWest
    the ig not embeding on the first try is a timeing issue (SB related) and seems to be different for each machine as to how fast it can load IG. There is a thread around here that has a HOW TO on how to make it so SB embeds IG perfectly every time. I'll have to dig it up and put a link here. I have the same issues with IG in my car sometimes it wont embed on the first try if for some reason its loading slower than normal.
    As for the touchscreen stuff, at exactly what point do you loose the touchscreen. And when you say touchscreen, do you mean you loose ALL touchscreen functions on the computer? ie; the hardware is not working anymore inside or outside of Road Runner? OR do you mean that RR stops responding to mouse clicks either from a physical mouse or TS.
    What do you do when you loose TS? How are you putting the computer into hybernation? w keyboard?
    mp3car live search
  10. #130
    Jul 2005
    SD, CA
    that didn't work, however clicking time while at the main menu does give me a fullscreen vis. thanks again LS, this skin is awesome.
