the pop up menu is an add on, check the first postOriginally Posted by Civic03
Has anyone gotten the pop up menu to work?
PROGRESS 95%[//////////■]Complete - Software configurations
Current Task: Just adding on...
Needed:wireless keyboard/mouse
My Carputer Blog
Car System Site
beer replenishment fund
mp3car live search
I downloaded it and put it inside the LSX skin folder but nothing happens when I click on the clock.
My Carputer Blog
Car System Site
im gonna go out on a limb and say i dont think you copied the files correctly.
inside of the LSX directory , you should see these files
POPUP.skin
ExecTBL.ini
If you have a folder named popup_menu inside of the LSX folder, this is wrong
all loose files inside of the rar file should be in the ROOT of the skin folder.
mp3car live search
i just repacked the rar file to remove the extra folders, so you should only see loose files, for anyone in the future who has the same problem.
mp3car live search
sorry for my english....!!(italian man)
Is possible to write to me because in my skin (ls 3.0) the speed and the num. sat is not work??
I set in RRconfig....GPS => MapPoint, num. port=>5 (my gps port) ed "no internationalinal" and high speed = 130 Km/h...but the speedo and num sat = 0 !!!
Is possible to help me???
Thank all & thank to liquid smoke!!!
i think there is something wrong with this in the latest version of RoadRunner, none of my speedo's work anymore either. I think there is something you need to change or do to fix it, but havnet had the time to figure out why they dont work anymore.
also you may want to upgrade from ls3.0 to LSX
mp3car live search
First for the kudos. As everyone has said this is an amazing skin and quite frankly the reason I went with RoadRunner over FrodoPlayer.
Now for the question(s).
I used your revamped .exe file for iGuidance. It says for version 2.1NA Mine is 2.14 or something similar and it seems to work pretty well. However whether I have your modified .exe file or the original I have this issue. Sometimes the menu buttons you've designed work, sometimes they don't. The main problem with the modified .exe is that when they don't work then I can't even use iGuidance's smaller menu button. What can I do to make these more reliable?
Secondly, I have previously had no problems with the fullscreen mode, in fact I thought it was wonderful, but for some reason now when I go fullscreen it will not exit. If I press the minimize button it flashes the screen with the menu buttons briefly but goes right back into the fullscreen mode. I recently applied the minlogon hack to windows but I'm unclear as to why that would cause a problem. It seems to have caused a few others too, but that is for another forum.
Lastly, I never had the split com function with the speedometer working but I was thinking about tackling that problem. I see from your last post that it is an issue with the new RR and just wanted to say that I am eagerly awaiting a possible fix.
the buttons for IG not working 100% is a known issue, basicly the issue is window focus. If you click on the map, then click the buttons they work. I think there is a solution to this somewhere, have to dig it up. As for the smaller iGuidance menu button, its still there, the images used for it is just 100% transparent. But the area where the button was at still works if you click on it.Originally Posted by Rabid_Child
fullscreen: when u update to the latest ver of RR, it replaces the KeyTBL.ini file in the root of RR, recopy the one from the skin and it should work again.
You will have to do this everytime you update to a newer ver of RR.
well the split com thing sounds like you have 2 problems.
For it to work, you will still need to have your gps com port split, what app are you using to do this?
Second, there is a issue with this feature in the latest ver of RR, i read in another post guino saying there is a fix for this or something to that effect, i just have to get some time to look at it and see whats going on.
mp3car live search
Originally Posted by liquid_smoke
Thank you very much for the help. I am using Xport3 for the com split. I did some checking around the forums and this is what I found concerning the split com issue.
With the new version of roadrunner you need to edit the rr.ini file to include GPSPORT=X Where X is the correct com port. On the same thread Guino says not to use Mappoint for the GPS program but I kept the settings as your thread suggests and using mappoint and adding that line works just fine.
Now I have these questions:
First, how do I change the units to MPH instead of Kilometers? Probably a RoadRunner config and not your skin but thought I'd ask.
Secondly, your default WV logo has the clock then a speedometer. My downloaded Subaru logo just has the clock. How can I restore the speedometer function?
Thank you very much and keep up the good work.
